Since I updated to 2.8, every time I sync in Revit, this loading screen appears in enscape. And its just stuck there. The only way to get rid of it is to close revit and reopen.
Update It appears that Enscape thinks that 3D View got deleted. But it didnt.
Thanks,
In this case a feedback report with your log files would be great to analyze the cause behind this:
https://enscape3d.com/community/blog/knowledgebase/using-the-feedback-button/
Is there anything at all you did prior to this issue? Or did this actually occur right after you’ve upgraded?
Does it help if you remove the 3D View though, and did you perhaps had settings linked to that view as well?
