I’m having trouble with bushes and trees showing up correctly. I am working together with another user and he has inserted bushes in the Revit model, but his Enscape rendering shows the bushes completely different then mine. Any ideas why this is happening. We are working from the same Revit file and have made sure everything is exactly the same on the Revit side of things.
Thanks for any help you can provide!
HI @BMerk_RPAP ,
the reason why your RPC models do look different seen through Enscape is that by default they are being replaced automatically by better looking 3D models provided by Enscape.
To view your RPC elements the way they appear in Revit, simply deactivate the ‘Replace Archvision Content’ setting in the ‘Advanced’ settings tab:
Restart the Enscape window once for the setting to have effect. Afterwards, RPC elements should be displayed exactly as they appear in Revit.
