Wrong RCP shrub (BOXWOOD SHRUB) shows up in Enscape, but looks correct in Revit 2016.
Any idea why or how to fix?
@Lin_1 - Do you have the ‘Replace ArchVision Content’ checkbox in the General Settings → Revit section in Enscape?
I unchecked it which worked, but then all the other trees changed.
@Lin_1 - the mapping can result in this kind of behavior as the default set of RPC elements which is being shipped with Revit is being replaced each by a fixed 3D model. Enscape will recognize the RPC used and exchange it by a particular 3D model. These should correlate in terms of shape, size and type of plant with the RPC elements they replace, however, they don’t display exactly the same image.
We used to have an RPC sample project file that would show a neatly arranged overview with all the RPC elements and their replacements in Enscape. I think this is out of date though. Ill ask around and see if I can find an answer to that.
