Revit Trees not appearing in Enscape
Hi. My first post here so I hope someone can help.
First off, I’m running Revit 2023 and Enscape 3.4.0 +84039.
I have an issue where trees are showing in Revit but not in Enscape. I have attached 2 images. 1 is Revit showing the following trees…
Planting_RPC_Tree_Diciduous - Siberian_Crab_Apple-6.1_Meters
Planting_RPC_Tree_Conifer - Colorado_Spruce-4.0_Meters
As you see in Revit they display fine but in Encsape only the Crab apple tree is visible. Any ideas what’s happening?
If I use a tree from the Enscape asset and insert into my revit model, its renders fine in Enscape but in realistic mode in Revit, its just a grey tree outline, where it would be nice to see a realistic tree in Revit (like my attached example) for my scaled elevation plans etc.
EDIT…
I’ve just inserted all the trees that come as standard with revit and only the Crab apple tree is visible in Enscape!
By default Enscape replaces Revit RPC content. You can choose to render Enscape Assets or Revit RPC content. You can’t render both. https://enscape3d.com/community/blog/knowledgebase/entourage-rpc-content/
Did this only come in with the last update? I’ve never had this issue until now, but now I find myself having to replace all RPC trees on existing projects where until recently, they rendered perfectly fine.
I’ve been working with the same Revit project for several months, and it has been upgraded with each release of Revit. I keep my Enscape version up to date as well. So I’m currently running Revit 2023.0.2 and Enscape 3.4.0+84039 with NVIDIA Studio Driver 516.94.
As recently as June 2022, I always used to see the Enscape trees automatically substituted for the native RPC ones. Many happy little trees. I am confident that something has changed with regard to RPC trees in the most recent release of Enscape. None of my trees appear at all in Enscape, although they do show in the corresponding Revit view. RPC people still appear, but no trees. Just sad naked topography.
I’ve tried toggling off and on the “Replace ArchVision Content” option in General Settings → Revit and restarting, but interestingly, that doesn’t seem to do anything at all. I’ve also tried deleting all the new site context stuff, and that didn’t change anything either.
I think this is a bug. Or am I missing something?
I am also having this problem. Phil’s response didn’t help, because we’re not trying to mix RPC and Enscape assets. The automatic substitution of Enscape assets for RPC trees is not working correctly. Also, unchecking the option does not bring back the native RPC for me either.
If you’re downloading assets locally, please uncheck the download open and recheck in order to force re-sync of the Enscape assets.
I tried forcing re-syncing of offline assets, but that didn’t work. Neither did rolling back a release or forward to a preview release. I gave up and spent hours duplicating all the RPC trees with new ones from the Enscape asset library.
I’m having the same issue. I need to get renderings done and my assets are not showing up.
Hi @Mike_Ferne , @kalbrau , @graycedar and @davisba82
Welcome to our forum and apologies for the late reply.
Would it be possible for some of you to share a test project with us where this is happening for you, please send in a project where trees and other assets are in.
You can share them with us via a WeTransfer link, these can be sent to with a link to this forum thread and my name attached to it for context.
