Rhino crashes when working in Vray Vantage, this happens only when selecting a material in rhino with vantage open.
I’m getting this data from windows event manager:
Application: Rhino.exe CoreCLR Version: 7.0.2024.26716 .NET Version: 7.0.20 Description: The process was terminated due to an unhandled exception. Exception Info: System.AccessViolationException: Attempted to read or write protected memory. This is often an indication that other memory is corrupt. Stack: at UnsafeNativeMethods.Rdk\_Globals\_GenerateQuickConte ntPreview(IntPtr,
Please give me some hint where I can fix the issue.
Looking forward to hear from you.
Thanks,
Jacob
Stack:
at UnsafeNativeMethods.Rdk_Globals_GenerateQuickConte ntPreview(IntPtr, Int32, Int32, IntPtr, Boolean, Int32, UInt32 ByRef)
at Rhino.Render.RenderContent.GenerateQuickContentPre view(Rhino.Render.RenderContent, Int32, Int32, Rhino.Render.PreviewSceneServer, Boolean, Int32, Rhino.Commands.Result ByRef)
at RDK.Controls.NewContentControl.NewContentCtrlViewM odel.GenerateQuickContentPreview(Rhino.Render.Rend erContent, Boolean, Rhino.Render.PreviewAppearance, Rhino.Render.SceneServerDataUsage, Int32, Rhino.Commands.Result ByRef, Int32, Int32)
at RDK.Controls.NewContentControl.NewContentCtrlViewM odel.CreatePreviewImagesAll(Boolean)
at RDK.Controls.NewContentControl.NewContentCtrlViewM odel.DisplayData()
at RDK.Controls.NewContentControl.NewContentCtrlViewM odel.OnDataChanged(System.Object, Rhino.UI.Controls.DataSource.EventInfoArgs)
at UnsafeNativeMethods.IRhinoUiController_Commit(IntP tr, System.Guid)
at RDK.Controls.GenericController.Commit(System.Guid)
at RDK.Controls.NewContentControl.NewContentCtrlViewM odel.SelectContents(Rhino.Render.RenderContentColl ection)
at RDK.Controls.NewContentControl.NewContentCtrl.Sele ctContents(Rhino.Render.RenderContentCollection)
at RDK.Panels.ObjectMaterialPropertiesPage.ObjectMate rialSection.RefreshUICallback()
at RDK.Panels.ObjectMaterialPropertiesPage.ObjectMate rialSection.RefreshUI()
at RDK.Panels.ObjectMaterialPropertiesPage.ObjectMate rialSection.DisplayData(Rhino.RhinoDoc, Rhino.DocObjects.RhinoObject[])
at RDK.Panels.ObjectMaterialPropertiesPage.ObjectMate rialPropertiesPage.UpdatePage(Rhino.UI.ObjectPrope rtiesPageEventArgs)
at Rhino.UI.RhinoPageHooks.PropertiesPanelUpdatePageH ook(IntPtr, System.Guid)
