So before I tell you guys about my problem, you should know that I’m a Noob in 3ds Max and I normally use Cinema 4d.
So the problem that I have is, when I add fog in corona by using an Volume material like this:
The opacity map kinda dissappears from my backdrop.
Without Fog:
With Fog:
This is my scene btw:
I hope somebody can help me.
And Yeah I tried increasing enviro distance in development and experimental stuff.
PROH
2
Hi. Just a couple of question to understand your setup:
- What is that dome for? - If the dome is used for the Volume Material, then try to use Global Volume Material instead.
- Are your camera(s) placed inside the dome? - If the dome is used for the Volume Material, then the camera must be placed outside the dome.
The dome is used for volume material so I will try that
And the cameras are placed inside the dome so I will try that too
I tried moving the dome so that the cameras are outside of it and it works.
Thank you very much for your help.
