Support Houdini engine for 3dmax
Hello Svetlin
Could you support houdini engine for ph3 ?
Because the way for emitting particles in houdini is much easier than Pflow in max. under some condition I want to directly pick houdini particle as PH source, is that possible to adding this feature to PH3 ?
about houdini engine check this video Introducing the Houdini Engine.
There are standard particle systems in Max that we can support - I believe once we add support for Krakatoa particles as a source, Houdini engine particles will be automatically supported as well. I hope this will happen during the coming months
