In my remembrance I red this before, but I forgot, but, is it possible to Enscape a textured or have a photo on glass and keep a kind of transparancy with the render?
Tnx,
Remco
Tnx,
Remco
Hey @RemcoNL_1 , pardon if I’m missing something but, you should be able to achieve what you’re looking for by just assigning a material to both faces of a window (for example), inside and outside, so on four faces all together:
If you’re using a single plane only, then just assign the material to the corresponding two faces instead.
Afterward, open our “Enscape Materials” window and activate “Transparency” by clicking the checkbox left to it. Then, add as much “Opacity” as you like. Is this what you were looking for? ![]()
Tnx, Demian, I will give it a try!
