V-Ray 7, Update 4, Hotfix 1, available for download
V-Ray 7, Update 4, Hotfix 1, is now available for download from our website for 3ds Max 2022-2027
Build: 7.40.02
Modified features
V-Ray
  • Еxtend the object gizmos overlap avoidance in Chaos Vantage in viewport
  • Set V-Ray GPU as ActiveShade renderer when choosing V-Ray for the production renderer
  • Support for ThinkingParticles in 3ds Max 2027
  • Switch Wireframe override viewport mode to Default shading mode while Chaos Vantage is running in 3ds Max’s viewport
VFB
  • Change the log parameters from scene oriented to user oriented
  • Add minimize button to the log when it is detatched from the VFB
V-Ray Toolbar
  • Change the default option to Chaos Vantage in viewport from the Chaos Vantage toolbar menu
Bug Fixes
V-Ray
  • Chaos Vantage viewport ActiveShade uses locked viewport’s projection instead of the active viewport
  • VRayMtl SSS data is written in the VRayRefraction render element when used with VRayBlendMtl
  • Per-viewport filters are not saved when restarting Chaos Vantage in the viewport
  • Distributed Rendering 2 (DR2) does not work with Backburner
  • Crash with Chaos Vantage in viewport when resizing 3ds Max window
  • Random crash with VRayProxy and Chaos Vantage in viewport
  • Crash on Reset after rendering VRayBitmaps with user tags with Distributed Rendering 2 (DR2) and localhost enabled
  • Show Histogram doesn’t trigger immediate persistent settings save
V-Ray Toolbar
  • Button state in Chaos Vantage toolbar is not updated on Chaos Vantage viewport start/stop from the viewport ActiveShade option
I’m concerned about the lack of tyFlow Volume support.
ARNOLD already supports it.
Please, where is tyflow Inferno support?
Nice one on the Backburner + DR2 crash fix, that combo’s been a real pain point for studios still on backburner. Vantage/VRayProxy stability fix is welcome too.
