vray 1.50 glossy reflection problem
hi
i have a problem with glossy refection problems in vray 1.50sp1
in VR1.50 the reflection looks fine
this is the rendering and the max file ( max2008 )
http://rapidshare.com/files/71276596/vray\_sp1\_test.zip.html
regards
richard
If you use Phong BRDF for your floor material rather than the default Blinn, it will go away.
it works :slight_smile:
many thx vlado for the quick answer
Is this a bug or by design?
that’s what I was wondering, because it seems to work as it should here. both with phong and blinn (actually there seems to be something weird going on with ward, but I never use it).
You might say that it is by design; this is because of the fix for the dark edges when using the VRayEdgesTex map as a bump map.
The two issues are exclusive - if I fix one, I will break the other. This is due to the nature of the Blinn/Ward BRDF definitions.
The only solution for both cases would be the V-Ray BRDF which we are working on.
Woot!! Looking forward to that one most definately :smile:
and which I’d really like to work with :slight_smile:
thanks for the clarification.
thats definetely great news vlado!
:slight_smile:
Thanks Vlado and looking forward to a new BRDF in the future.
