Hi, I was wondering whether someone may be able to assist me with the highlighted error messages below (printed from deadline):
At the moment it is rendering garbled images.
2020-10-07 19:27:21: 0: STDOUT: Loading C:\Program Files\Common Files/Nuke/12.1/plugins\vray/VRayPlane.dll
2020-10-07 19:27:21: 0: STDOUT: Loading C:\Program Files\Common Files/Nuke/12.1/plugins\vray/VRayObjProp.dll
2020-10-07 19:27:21: 0: STDOUT: Loading C:\Program Files\Common Files/Nuke/12.1/plugins\vray/VRayVRScene2.dll
2020-10-07 19:27:21: 0: STDOUT: Loading C:\Program Files\Common Files/Nuke/12.1/plugins\vray/VRayRenderer.dll
2020-10-07 19:27:21: 0: STDOUT: [2020/Oct/7|19:27:21] Global | Created log file: C:\Users\RENDER~1.SEC\AppData\Local\Temp/vray4nuke_log.txt
2020-10-07 19:27:21: 0: STDOUT: [2020/Oct/7|19:27:21] Global | V-Ray for NUKE version 4.30.00 HWLIC, revision a4fe949a from Jun 5 2020, 13:08:54
2020-10-07 19:27:21: 0: STDOUT: [2020/Oct/7|19:27:21] Global | Console verbosity level set to : “Errors warning and informational messages”
2020-10-07 19:27:21: 0: STDOUT: [2020/Oct/7|19:27:21] Global | Log file verbosity level set to : “Errors warning and informational messages”
2020-10-07 19:27:21: 0: STDOUT: Loading C:/Program Files/Nuke12.1v4/plugins/exrWriter.dll
2020-10-07 19:27:22: 0: STDOUT: [19:27:21 E. Australia Standard Time] Read nuke script: C:/Users/rendernode.secure/AppData/Local/Thinkbox/Deadline10/slave/S-BLADE-15/jobsData/5f7d89d21fc1c50b9c3ccc51/thread0_temptyrZU0/egd_1001_Variation 1 - HoboLighting_cmp.0002.nk
2020-10-07 19:27:22: 0: STDOUT: [19:27.22] Warning: VRayProxy1: Knob:file_info. Setting knob values from validate is not supported and may cause unexpected behaviour.
2020-10-07 19:27:22: 0: STDOUT: [19:27.22] Warning: Accessing BackdropNode children nodes is only possible in GUI mode.
2020-10-07 19:27:22: 0: STDOUT: [19:27.22] Warning: VRayRenderer2: Abort/cancel checked with no valid trees. This op most likely needs to have its parent set correctly.
2020-10-07 19:27:22: 0: WARNING: Skipping error detection as ‘Continue On Error’ is enabled.
2020-10-07 19:27:22: 0: STDOUT: [19:27.22] ERROR: VRayRenderer2: Environment variable VRAY_FOR_NUKE_12_1_PLUGINS is not defined!
2020-10-07 19:27:22: 0: STDOUT: Writing S:/d_production/designschool/c_shots/01 - Edna’s Grand Debut/egd_1001_Variation 1 - HoboLighting/h_precomp/StageLighting/StageLighting.0000.exr [2020/Oct/7|19:27:22] VRayRenderer2 | error: Environment variable VRAY_FOR_NUKE_12_1_PLUGINS is not defined!
2020-10-07 19:27:22: 0: STDOUT: [19:27.22] ERROR: VRayRenderer2: V-Ray initialization failed: Error
2020-10-07 19:27:22: 0: STDOUT: [2020/Oct/7|19:27:22] VRayRenderer2 | error: V-Ray initialization failed: Error
2020-10-07 19:27:39: 0: STDOUT: Writing S:/d_production/designschool/c_shots/01 - Edna’s Grand Debut/egd_1001_Variation 1 - HoboLighting/h_precomp/StageLighting/StageLighting.0000.exr took 16.77 seconds
2020-10-07 19:27:39: 0: STDOUT: Frame 0 (1 of 5)
2020-10-07 19:27:39: 0: STDOUT: [19:27.39] Warning: VRayMtl7: Knob:input_count. Setting knob values from validate is not supported and may cause unexpected behaviour.
2020-10-07 19:27:39: 0: STDOUT: [19:27.39] Warning: VRayMtl1: Knob:input_count. Setting knob values from validate is not supported and may cause unexpected behaviour.
2020-10-07 19:27:40: 0: STDOUT: Writing S:/d_production/designschool/c_shots/01 - Edna’s Grand Debut/egd_1001_Variation 1 - HoboLighting/h_precomp/StageLighting/StageLighting.0001.exr [2020/Oct/7|19:27:40]
