I am trying to mimic the sun light via using Vray LightRectangle plug-in and setting its “is disc” on. However, I can’t wrap my head around to get this node to work in Maya. Here below are some screen shots. I tried to plug a sun disc cropped from Nuke as texture but no matter how I tweak each parameters (intensity, diffuse contribution etc), I couldn’t see its diffuse contribution to the scene?
Am I using it right or I am missing something?
Also, there is no viewport manipulator support for this light plug-in yet which I hope isn’t a big issue if I can probably use a aim constraint to control the direction of the light.
ivaylo, in a empty new scene, I have tried executing the script you provided with or without a newly created standard rect light being selected. I got the error below
# Error: Exception: file C:\Program Files\Autodesk\Maya2016\vray\scripts\vray\utils.py line 44: The vray.pluginmodifier module wasn't initialized properly. One possible reason for this error is that you are trying to execute the script from the Script Editor. The script must be placed inside the special field that V-Ray provides for Python code (Render Settings / VRay Common / MEL/Python Callbacks / Post Translate Python Script) #
I am on Windows 7 x64, Maya 2016. V-Ray for Maya 3.1. I executed it as Python script.
Thanks ivaylo…My bad to not scroll to the right enough to check the whole message. It is working as expected now, Unfortunately not working with RT, as soon as I move the light, it changes to rect shape again…
Will the UI of “is disc” being exposed for upcoming Maya? I remember this is available for Max for a while…
