kenzor
February 20, 2018, 2:45am
1
Vray RT only renders a single frame of my sequence before crashing out ( 3dsMax is fine only vray fails )
both CUDA and CPU renders fail in the same way. Vray adv renders the sequence without issue.
I’m running the latest version of 3dsmax2018 with the latest version of vray using an nvidia 1080 under windows 10.
I did a clean install of everything a couple of weeks ago when win 10 died and I had to rebuild everything from scratch.
The vray log reveals little just an ‘exception error’.
In general I don’t have much with Vray RT , any suggestions on how I diagnose and fix the problem ?
Which V-Ray version is that?
If you are using 3.60.04, can you send the scene over so we can check?
Best,
Blago.
kenzor
February 20, 2018, 2:03pm
3
Tthanks for your help. I’m on vray 3.60.04. Is there a way I can send a file privately ? Wetransfer ?
Yes. Please mail to peter.matanov@chaosgroup.com with cc to blagovest.taskov@chaosgroup.com with link to the scene and to this thread.
Thanks!
Best,
Blago.
kenzor
February 22, 2018, 5:23pm
5
Hi Peter, I Just sent you a file via wetransfer. If you need other details of my PC setup here just let me know.
Many thanks - ken
matanov
February 23, 2018, 11:52am
6
Hey,
There are a lot of 3ds max materials and textures in the scene which seem to bug the export. Just run our scene converter and it should stop crashing (right click in the viewport - V-Ray scene converter ).
kenzor
February 23, 2018, 2:51pm
7
That works for me . Many thanks peter
