VrayEdgesTex produces serrated edges
I have an issue with VrayEdgesTex producing serrated edges when I use it in the bump slot for rounded corners effect. The thin ring in the middle is a separate object and doesn’t even touch the other 2 objects it’s next to it. Please see the screenshot below.
Nevermind, I solved the “mystery”. The serrated object actually had triangle shaped polygons deleted just behind that ring. :stuck_out_tongue:
