WIP Light and Space (updated)
Hi guys started this render as a light study but saw the potential for more. I am currently thinking of what else i could do to complete and improve the scene any comments are welcome.
Simple with a bit of postprocessing
Added texturing and objects still a simple space but with more grunge and as usual comments are welcome.
Re: WIP Light and Space
pretty nice image chisel.
it looks pretty realistic
i think you could improve your settings, and also increase the reflection layer multiplier of the wood, cause there’s a little bit of noise there
Thanks for the reply Steve, the settings were not yet set to a final render quality. I agree with you on the timber flooring will make that adjustment for the updated post.
Chisel , good job
i like your curtain , do you use VRAY2SIDEDMTL for this curtain ?
it looks like a hotel hall. very nice.
simplicity is what makes this so good.
could you share the plant please?
Yes robert111 the i used the two-sided material to create translucent effect. Thanks for the kind words
Sookie thanks for the comment i was going for a simple feel but for some reason it still looks unfinished as a render so i am still playing around with the scene will post an update soon. BTW the plant can be found here http://www.flyingarchitecture.com/
thanks chisel
can you make VRAY2SIDEDMTL setting for your the curtain plz
Like like “facebook style”. I think correct the verticality distortion.
Re: WIP Light and Space (updated)
One more thing the image was not renderd at a very high resolution as this was a theoretical project.
great improvement!
wow very realistic Chisel.. great work, i agree with Omar
nice study - renders downloaded.
Thanks for the comments guys im glad it came out this well, i will keep doing some studies to improve my skills its better practice than on a job cause you are not bombarded by the time line for production. I found that it helps to design the scene first with an intention as to the mood and feel then do research taking references from images that convey the mood. Cheers
