It softens corners in rendering.
having a hard time installing, so i wasn’t sure if vray was compatible with it.
Re: would this work?
It doesn’t work (yet?), but you can extract the softened rendermesh with that plugin.
Glad you asked about it. I saw it, loaded it and extracted the mesh. It has already helped out on some renders. The look falls apart when you get much bigger than 1-2 mm or get really close but I think those are the intended limitations. It is a nice short-hand solution.
