Overclocking Threadripper 2950X
  • #16
    Yep all 4 from one kit. (I made that mistake once, It won't happen again as the resulting system wasn't very stable)
    I can give you the model number when I'm at home later since I put it together there and the packaging is still in my basement.
    Yep I took the second Profile like you said. (3200 16-18-18-38 )
    I did a few test starts and it still happens.
    Windows is 1903 yes.
    German guy, sorry for my English.
    • #17
      I realized one of the fans on my water cooler is broken. I'll get a new one. Maybe I can make 4.1 run quietly with all 3 running. But that'll be sometime next week.
      • #18
        Ihno
        I actually don't recommend that cooler and in my other posts I told others to stay away from it
        The first and second Generation had a manufacturing defect, and in 2-3 months the pump would fail because of corrosion .. Basically they fucked up the metal mixture they used in various parts of their pump, which is an unforgivable mistake
        Nothing like this happened before to such a high end cooler
        You would be suprised if I told you I had over 25 units fail which is basically every single unit, then we stopped using them completely .. Other people here on forum got up to 5 replacements, all of them failed.
        If you can send that back because of the fan, that would be great. Stick to Corsair H115i Pro or H150i or NZXT Kraken X72
        If you decide to keep it, you will need to keep an eye on your temps regularly
        Muhammed Hamed
        V-Ray GPU product specialist
        chaos.com
        • #19
          Damn I somehow I did not see those posts about that cooler.
          I'll try to get one of the Corsairs
          Here is the back of the packaging:
          • #20
            Thanks Ihno
            Will write you some timings to use tonight,
            they should work out of box
            Best,
            Muhammed
            Muhammed Hamed
            chaos.com
            • #21
              Will probably stay at office late today for few things, sorry for the delay
              Will write you here in few hours
              Muhammed Hamed
              chaos.com
              • #22
                No need to rush! I won't be at the office till monday. Relax! I hope you can go home soon.
                • #23
                  I'm lucky, I'll get a refund for that cooler, and we'll buy the H150i PRO instead.
                  • #24
                    Ihno Very good to hear!
                    the H150i is just piece of mind, let me know how it goes
                    For RAM, I will be in office shortly.. will screenshot you the timings from one of the machines that had the same problem as you
                    Muhammed Hamed
                    chaos.com
                    • #25
                      Hey Ihno
                      Lets try few things now,
                      I want you to load optimized defaults, then enable A-XMP, then choose the correct profile for your RAM
                      then you should enable the memory try it feature, set it to Samsung it might help
                      Lets then reboot and see if the OC is always working
                      If you still having the same issue, let's disable A-XMP, and setting the DRAM frequency manually to 3200
                      And enable memory try it again
                      Then click on Advanced DRAM configuration, you will need to try 1.4 volts, which is totally save for 24/7 usage
                      Save and reboot, then see if this makes the OC stable
                      Let me know how it goes
                      Muhammed Hamed
                      chaos.com
                      • #26
                        Memory try it lets me choose a profile and it disables xamp. So I couldn't test both at the same time. Memory try it only didn't work. I tested 2 - 3200 profiles. Memory try it with higher voltage (1.4 instead of 1.380) didn't work either. I disabled memory try it and xamp - choose 3200 as frequency and 1.4v and this seems to work. It always starts with 3200.
                        • #27
                          I'll need more test starts . But for today I'm going home. Thanks for all the help I truly owe you some beer.
                          • #28
                            Good to hear it worked for you, Tomorrow you will need to reapply the CPU OC and most importantly disable PBO again
                            Then test stability for few hours, but fingered crossed, this should work nicely hopefully
                            I trade that beer with coffee
                            There is a slight chance we might need to do manual timings, but hopefully not
                            Muhammed Hamed
                            chaos.com
                            • #29
                              It seems to work. I'll start the longer stress test when I go home later, but till now it seems to be stable. And it boots with 3200 every time.
                              • #30
                                Good to hear!
                                Did you reapply the CPU OC again?
                                Take your time on testing stability, fingers crossed
                                Ping me here if something happens, or when you are ready for GPU OCing
                                Best,
                                Muhammed
                                Muhammed Hamed
                                chaos.com
