I read bad reviews about the risers...which ones did you go with?
nVidia 1080 ti
Originally posted by biochemical_animations View PostI read bad reviews about the risers...which ones did you go with?
http://www.ebay.com/itm/162273850492...%3AMEBIDX%3AITArchitectural and Product Visualization at MITVIZ
http://www.mitviz.com/
http://mitviz.blogspot.com/
http://www.flickr.com/photos/shawnmitford/
i7 5960@4 GHZm, 64 gigs Ram, Geforce gtx 970, Geforce RTX 2080 ti x2
Originally posted by biochemical_animations View PostThanks. Those are different then the ribbon ones I read aboutArchitectural and Product Visualization at MITVIZ
Yep, after thinking about it, I'm probably in for a new workstation with four of these in the near future. The scene setup, lighting, materials, etc workflow will be greatly speed up with a super fast gpu rendering WS. I just have to pitch a bit more for some upcoming jobs to cover the investment. Once done, tho, the will be nice. Keeping my fingers crossed.
This along with rt gpu reworking that Vlado mentioned will be, I believe, an incredible boost to photoreal workflow.
Exciting times.
Originally posted by biochemical_animations View PostAnother option I was considering, was putting a liquid cooler on the card that has the least airflow. I'm concerned tho for leaks, so I would probably design the thing where if there were leaks, they would not drip on anything electrical...so maybe rotating the case in some way so leaks would avoid components...just some ideas.
Right now, I'm still going with blowers...but liquid cooling would enable higher OCing.
I think it's the same for 1080Ti.
Originally posted by mitviz View Posti know people using them, i also use them now, there is nothing bad about it, the place where i bought my gpus even recommended it, here is the one i bought from this exact seller
I'm not totally up to knowledge on transfer speeds on the MB vs riser.
Originally posted by biochemical_animations View PostAre there differences in load times using the risers vs plugged straight in th MB?
I'm not totally up to knowledge on transfer speeds on the MB vs riser.Architectural and Product Visualization at MITVIZ
you should be able to use all 6, am at 4 now, waiting on the 1080 ti to make it 5Architectural and Product Visualization at MITVIZ
Originally posted by iancamarillo View Postnice. does that mean you'd be limited in ram usage to the older cards? Do you know if processor frequency affects GPU rendering? Or is it just more cuda cores and ram the better?Architectural and Product Visualization at MITVIZ
Originally posted by iancamarillo View PostSorry I meant if you mix 1080's and 1080ti's, are you limited to the 1080's ram? And not utilizing all of the 1080ti's? I do a lot a arch renderings that take a LOT of ram and I want to use GPU in production but I'm not sure how much ram I need.
