Originally posted by glorybound
View Post
nVidia 1080 ti
Asus release three different 1080Ti :
GTX1080TI-FE : https://www.asus.com/Graphics-Cards/GTX1080TI-FE/
TURBO-GTX1080TI-11G : https://www.asus.com/Graphics-Cards/...GTX1080TI-11G/
ROG-STRIX-GTX1080TI-O11G-GAMING : https://www.asus.com/Graphics-Cards/...I-O11G-GAMING/
When we compare, apparently, no real hardware difference :
1x fan for the Founders Edition.
1x fan too for TURBO Edition but it's dual-ball Bearing Fan (less noise?)
and finally,
3x fans for ROG-GAMING edition, higher and wider than the others (2.5-Slot Width)
but no overclocking ?Last edited by Raph4; 14-03-2017, 12:38 AM.
Originally posted by biochemical_animations View PostOC'ing should accompany the 1080 ti...I read tests done at 2 GHz in order to get the 30-35% advantage over the 1080. I don't know if I would spend the $ if I couldn't OC them.Architectural and Product Visualization at MITVIZ
http://www.mitviz.com/
http://mitviz.blogspot.com/
http://www.flickr.com/photos/shawnmitford/
i7 5960@4 GHZm, 64 gigs Ram, Geforce gtx 970, Geforce RTX 2080 ti x2
Originally posted by mitviz View Postoverclocking just introduces more problems for graphic cards so better to stay at stock, especially when you have issues with the card and need to send it back, they can deny fixing it
OCing GPU for rendering is a lot different to OCing gpu for gaming. If u OC for rendering u don't have too much to worry about - at least last I checked. You can also hit higher OC than for games if u just will render it. < might be wrong but last time I tested I could get a lot more out of my GPU when I only used it for rendering and not games.
Originally posted by Dariusz Makowski (Dadal) View PostDepends on the brand. Usually EVGA will be glad to take OC damaged card. I think its even in ther RMA TOS that u can send OC damaged hardware.
OCing GPU for rendering is a lot different to OCing gpu for gaming. If u OC for rendering u don't have too much to worry about - at least last I checked. You can also hit higher OC than for games if u just will render it. < might be wrong but last time I tested I could get a lot more out of my GPU when I only used it for rendering and not games.Architectural and Product Visualization at MITVIZ
and finally,
A little more info for all Asus 1080Ti.
ASUS GTX 1080 Ti Founders Edition & ASUS TURBO GTX 1080 Ti & ASUS ROG STRIX GTX 1080 Ti GAMING
https://www.techpowerup.com/gpudb/28...ce-gtx-1080-ti
https://www.techpowerup.com/gpudb/b4...bo-gtx-1080-ti
https://www.techpowerup.com/gpudb/b4...1080-ti-gaming
GPU Base Clock: 1480 Mhz
GPU Boost Clock: 1582 MHz
Memory Clock: 1376 MHz
Render Config
Pixel Rate: 130.2 GPixel/s
Texture Rate: 332 GTexel/s
Floating-point performance: 10,609 GFLOPS
ASUS ROG STRIX GTX 1080 Ti GAMING OC
https://www.techpowerup.com/gpudb/b4...0-ti-gaming-oc
GPU Base Clock : 1594 MHz (+7.7%)
GPU Boost Clock : 1708 MHz (+8.0%)
Memory Clock : 1388 MHz (+0.9%)
Render Config
Pixel Rate: 138.1 GPixel/s
Texture Rate: 351 GTexel/s
Floating-point performance: 11,247 GFLOPS
One 1080Ti OC @ 2.5Ghz beat world record from Titan X (Pascal) on 3DMark.
GeForce GTX 1080 Ti overclocked to 2.5GHz sets world record
http://www.pcgamer.com/geforce-gtx-1...-world-record/Last edited by Raph4; 16-03-2017, 05:41 AM.
Originally posted by mitviz View Postactually there i think your wrong, rendering i think pushes gpus to the limit while games not so much, tried with the most punishing game benchmarks, highest settings etc gpu temps hardly move and the clock speeds are usually ok, when rendering however temps go up higher as well and the clock speeds and if your planning to overclock better have cooling, good cooling, at stock you can render and have no issues once your gpus arent close but once you plan to overclock you better be cooling which costs
Originally posted by biochemical_animations View PostMIT, have you tried one of those amfeltec splitter/clusters? I'm wondering if they would work on a regular MB and 28 lane cpu. My thinking, leave a card in the MB for the display running at 8x, and use a splitter/cluster in another slot adding 4 cards running at 4x. I've read guys using these on high end mb's, but I'm wondering if the high MB is necessary just for 5-6 card WS.Architectural and Product Visualization at MITVIZ
Hey MIT, did you have to do anything special to get those usb risers to work? I'm testing one, I have one card in the 16x MB slot, and another card in the riser...windows 7 reports errors with riser card. I've tried two different risers and two different cards in the riser, also tried a different slot...same thing. Windows doesn't like the riser card.
Originally posted by biochemical_animations View PostHey MIT, did you have to do anything special to get those usb risers to work? I'm testing one, I have one card in the 16x MB slot, and another card in the riser...windows 7 reports errors with riser card. I've tried two different risers and two different cards in the riser, also tried a different slot...same thing. Windows doesn't like the riser card.Architectural and Product Visualization at MITVIZ
I have been waiting for Virtual GPU technology to really happen. Is this even a reality?
http://www.nvidia.com/object/grid-technology.htmlBobby Parker
www.bobby-parker.com
e-mail: info@bobby-parker.com
phone: 2188206812
- 128gb Vengeance RGB Pro RAM
- NVIDIA GeForce RTX 4090 X2
- Windows 11 Pro
Originally posted by mitviz View Postno i didnt do anything special, you have the 60 cm usb 3 risers? let me see which one, also make sure you update your graphics drivers, for me i had to do nothing special just worked
I'm dumb!
Originally posted by biochemical_animations View PostI forgot to plug in power to the card...I powered the adapter and the card's fans came on, windows detected and loaded the driver but reported a problem...once I realized I forgot to power the card, it worked.
I'm dumb!Architectural and Product Visualization at MITVIZ
Originally posted by glorybound View PostI have been waiting for Virtual GPU technology to really happen. Is this even a reality?
