Originally posted by iancamarillo
View Post
nVidia 1080 ti
Architectural and Product Visualization at MITVIZ
http://www.mitviz.com/
http://mitviz.blogspot.com/
http://www.flickr.com/photos/shawnmitford/
i7 5960@4 GHZm, 64 gigs Ram, Geforce gtx 970, Geforce RTX 2080 ti x2
Originally posted by mitviz View Postno difference at all except that cards run much cooler
Also, I'm tying to brainstorm ways to hang the graphics cards externally...I've seen some youtube vids of crude wood frames...is that what you went with?
Right now one card in my boxes are running 84 degrees C top, as summer approaches and ambient temps increase, it would be nice not to have to air condition the room, and allow to fans to adequately cool the cards if mounted externally. I think I'll have to implement ths solution.
So far the reviews on these are adapters are much better than the ribbons.
Originally posted by biochemical_animations View PostJust a question on install to double check myself...so power goes to the 16x board as well as the graphics card as it normally would, and the 1x board plugs into the 16x slot on the MB, replacing the graphics card...do I have this right?
So far the reviews on these are adapters are much better than the ribbons.Architectural and Product Visualization at MITVIZ
Originally posted by mitviz View Postyes, the gpu plugs into the pcie slot of the psu and the extender as well has a port for pluging into one power cable from the psu as well, forgot the type, then the extender plugs into the slot of the gpu on the mother board, i have a simple wood frame as my setup as well, didnt bother doing anything fany for now but here is something like what i did[ATTACH=CONFIG]36750[/ATTACH][ATTACH=CONFIG]36751[/ATTACH]
[QUOTE=Dariusz Makowski (Dadal);729644]I wonder how well this can work when the new NVLink comes in to play... humh[/QUOTED Dont here much talk about NVlink really, will it ever be available to us normal people over the next few years, knowing NVidia, probably notArchitectural and Product Visualization at MITVIZ
[QUOTE=mitviz;729692]Originally posted by Dariusz Makowski (Dadal) View PostI wonder how well this can work when the new NVLink comes in to play... humh[/QUOTED Dont here much talk about NVlink really, will it ever be available to us normal people over the next few years, knowing NVidia, probably not
Originally posted by kosso_olli View PostWho is the manufacturer of the aluminium frame construction? Can I buy these as shown?Architectural and Product Visualization at MITVIZ
Originally posted by mitviz View Postyou should be able to use all 6, am at 4 now, waiting on the 1080 ti to make it 5
I'm curious as to how the 1x adapters effects things like working in active shade.
Im still learning all this, but the way I understand it, that if you run a 40 lane CPU, you can have four gpus plugged into the MB, at 8x each, that's 32 lanes for the gpus.
What if you went with a regular 28 lane gpu, and plugged one gpu into the MB running at 16x for running the monitors ( I'm assuming graphic output cards need the 16 lanes on the MB), then added cards using the risers plugged into as many pcie slots as your MB supports? I'm guessing you'd still want a MB with as many 3.0 pcie slots as possible, so the 1x adapter gets the fastest transfer rate as possible. But would your workstation benefit the same with the 28 lane cpu setup with risers, as it would with a 40 lane cpu non-riser setup?
So lets say, one gpu at 16x plugged in the MB, then 4 more at 1x, that's only 20 lanes...am I getting this right?
Originally posted by iancamarillo View Posthmmm. so if i bought 6 1070's and some power I could use all 6 cards? do you know if theres a limit?
For us laymen... The 1080 Ti is FINALLY here and, while expensive, it's actually kind of amazing..
https://www.youtube.com/watch?v=L34Z...ampaign=bufferBobby Parker
www.bobby-parker.com
e-mail: info@bobby-parker.com
phone: 2188206812
- 128gb Vengeance RGB Pro RAM
- NVIDIA GeForce RTX 4090 X2
- Windows 11 Pro
Just ordered one of them for testing. If it goes well, and vray gpu behaves I'm planning to switch entire farm to all gtx 1080tiWill see how this goes
Dmitry Vinnik
Silhouette Images Inc.
ShowReel:
That NVlink sounds like something to wait for. I wonder if it'll be backwards compatible, or it'll need a new kind of card.Bobby Parker
phone: 2188206812
- Windows 11 Pro
