Does fstorm have a stated or explicit gamma setting? Looks more like a 1.8 gamma than 2.2.
Fstorm render
Originally posted by dlparisi View PostDoes fstorm have a stated or explicit gamma setting? Looks more like a 1.8 gamma than 2.2.Architectural and Product Visualization at MITVIZ
http://www.mitviz.com/
http://mitviz.blogspot.com/
http://www.flickr.com/photos/shawnmitford/
i7 5960@4 GHZm, 64 gigs Ram, Geforce gtx 970, Geforce RTX 2080 ti x2
I saved a jpg from both and the FStorm saved dark, so I applied a 2.2 gamma to it in PS.
Originally posted by dlparisi View PostDoes fstorm have a stated or explicit gamma setting? Looks more like a 1.8 gamma than 2.2.Bobby Parker
www.bobby-parker.com
e-mail: info@bobby-parker.com
phone: 2188206812
- 128gb Vengeance RGB Pro RAM
- NVIDIA GeForce RTX 4090 X2
- ​Windows 11 Pro
Originally posted by glorybound View PostIt is amazing how different FStorm and V-Ray look. The glass is totally different and so is the shadows, however, applying a curve to the V-Ray ones would produce the same effect.
I let V-Ray RT run as long as it took FStorm. V-Ray RT was pretty noisy until it got up and around 15 minutes. I did nothing but switch to VRay RT and hit render. Tweaking settings might speed things up, however, I just wanted to see what happens if someone who is fresh of the boat hits render. No settings were touched.Bobby Parker
phone: 2188206812
- ​Windows 11 Pro
Originally posted by glorybound View PostI let V-Ray RT run as long as it took FStorm. V-Ray RT was pretty noisy until it got up and around 15 minutes. I did nothing but switch to VRay RT and hit render. Tweaking settings might speed things up, however, I just wanted to see what happens if someone who is fresh of the boat hits render. No settings were touched.
It's hardly just gamma or tonemapping. No, just applying curve won't make it look the same.
You can never assume any scene will translate 1:1 to different renderer. Just look at the drawer handles. In Fstorm one, main key light source is window. In V-Ray one, there's fill light coming somewhere from behind the camera, that either got lost in translation completely, or translated wrong.
This set of pictures could only serve as an example of how well can Fstorm translate V-Ray scenes. But any comparison of lighting and shading in such circumstances would be completely off
You can't even compare performance in such case. There may be something that Fstorm translator translated in a way that makes it slower to render... something that would work a bit faster when set up from scratch.
I totally agree, however, one of the points was first time users producing incredible images.Bobby Parker
phone: 2188206812
- ​Windows 11 Pro
Originally posted by Recon442 View PostIt's hardly just gamma or tonemapping. No, just applying curve won't make it look the same.www.dpict3d.com - "That's a very nice rendering, Dave. I think you've improved a great deal." - HAL9000... At least I have one fan.
I doubt there will ever be any capable modern renderer that will ever use other gamma than 2.2. Fstorm does LFW like any other renderer, it's just that it has some slight tone mapping on top of it, but there's way more going on in Bobby's images than just different tone mapping.You can't really point at anything and say "It looks like Gamma *.*", there may be some tone mapping, or Photoshoping done to it.
Anyway, you can easily test your hypothesis. Download Bobby's V-Ray render and open it in Photoshop. 1.8/2.2=0.82, so just use Exposure adjustment layer in Photoshop, and set gamma slider to 0.82. At gamma 1.8, image will become slightly darker and more contrasty, but it won't magically shift to Fstorm looking image.
It's the GI clampling at 1.0 and the 8 diffuse bounces by default which make it contrasty.
the LC will distribute light across 100 bounces, making for a substantially brighter render, under identical color mapping conditions (those include Gamma, btw.)Lele
emanuele.lecchi@chaos.com
Disclaimer:
are there any plans to add stuff like this to vray? i mean vray can only improve, having the same tonemapping etc as octane and these others would make it the icing on the cakeArchitectural and Product Visualization at MITVIZ
Lele
Disclaimer:
Originally posted by ^Lele^ View PostArchitectural and Product Visualization at MITVIZ
