VRay Multimatte Renderelement free download!!!!!!!
  • #61
    i am not sure. did you ever let it render past the LC calc ? might be that they get added after first actual rendering...just a shot ino the dark as it looks okay so far.
    Thorsten
    • #62
      I've let it complete a render but its just the same. Could it be the version of Vray I am using? I'm on RC4 - not sure what iteration though.
      Kind Regards,
      Richard Birket
      http://www.blinkimage.com
      • #63
        ... and I am using MultiChannelMatte9x64RC4.dlv
        Kind Regards,
        Richard Birket
        • #64
          and u did cchange the object id in the properties form the default 0 to 1 or or 3...right?
          Nuno de Castro
          www.ene-digital.com
          nuno@ene-digital.com
          00351 917593145
          • #65
            Excuse me if I'm stating what's already been suggested and I missed it, or if I don't understand the problem, but don't you have to have the VFB off (uncheck the 'Enable build-in Frame Buffer' box) for the Render Elements to work? It looks like from your picture that the Render Element is not enabled.
            • #66
              i assume you dont wanna share that scene. Would it be possible to remove the geometry, put in three boxes and send me that scene ? then i could take a look at it after work.
              Thorsten
              • #67
                no, that's not necessary.
                • #68
                  When the V-Ray VFB is enabled, all V-Ray render elements will appear switched off in the Render Elements tab inside the Render Scene dialog. This is a work-around so that 3dsmax does not create its own render elements bitmaps - this is not required as the elements are stored in the V-Ray VFB itself. If the V-Ray VFB is used, the render elements can be enabled or disabled by using their own vrayVFB parameter.
                  Ah, ok, I re-read this from the VRay help site.
                  Thanks Joost Ink.
                  • #69
                    Will sort something out - cheers mate.
                    Kind Regards,
                    Richard Birket
                    • #70
                      actually tricky i've found something - plugin worked like a dream with Max 8 / RC3 / Max 9 RC3 / Max 9 64 bit RC3 64 bit,
                      however; i had some real bug issues with Max 9 and RC3, so vlado very kindly sorted me out with an updated RC4 build only last week - since then i can't get the plugin to work either - exaclty the same problem as you - it's just not in the drop down elements menu.....
                      Can only conclude it's a different build issue? Or can anyone else shed some light?
                      • #71
                        ok,
                        It's a build issue. The build in the zip file is a rc3 build and is wrongly named rc 4.
                        I can prepare a rc4 build for pre3 to 7. (newer ones are untested).
                        I will post them as soon as I have them ready.
                        Dieter
                        visit my developer blog
                        • #72
                          whoohooo, I've been quietly sulking because I couldn't use it with max8/RC4
                          probably no chance at a 1.49.23 version? :P
                          Eric Boer
                          Dev
                          • #73
                            would they still theoretically work however? Just not tested post 'pre release 7' builds?
                            Many thanks - your work is outstanding by the way. absolutely amazing. Every person who i show it too cannot believe it's not real. Also off topic - I noticed you guys use .exr files - how do you guys currently save out to .exr format using vray? I can imagine rendering to .vrimg and converting would become very time consuming for an image sequence....
                            • #74
                              I just couldn't test newer builds because I dont have them.
                              The new builds have the ability to directily write to exrs with all the channels from the framebuffer. Just change the filename from vrimg to exr.
                              Dieter
                              • #75
                                sorry - know this is off topic now - but this gives me an error?
                                I get fully black images for all channels out of the frame buffer channel splitter and an error when saving to vrimg but changing the extention to .exr?
