Cheatsheet: How to get a Cleaner image with SP3
  • #31
    Originally posted by ^Lele^ View Post
    Since you managed successfully the first approach, would you be so kind as to mention if you can see any noticeable differences in you new render, compared to the old?
    I do not want to prime your brain, so i won't tell you what to look for.
    The only noticeable difference was a slight color tone difference, I was baking in the gamma prior so that may have contributed, other than that that, the new auto algorithm worked very well.
    One issue I did encounter in my initial battery of tweaking and comparing settings back and forth was at some point the the new auto algorithm seemed to have broke, not matter what I was getting a noisy image no matter how much I lowered the noise threshold or loaded setting from previously clean renders from the VFB. I closed and re-opened the scene and the issue was gone.
    "I have not failed. I've just found 10,000 ways that won't work."
    Thomas A. Edison
    • #32
      On the MAX AA, why wouldn't you set it to 100? If you set it too low, I can see the issue, but you can't really set it to high. Isn't the color threshold the only thing you need to worry about? Or, maybe I am not thinking clearly.
      Bobby Parker
      www.bobby-parker.com
      e-mail: info@bobby-parker.com
      phone: 2188206812
      My current hardware setup:
      • Ryzen 9 5900x CPU
      • 128gb Vengeance RGB Pro RAM
      • NVIDIA GeForce RTX 4090 X2
      • ​Windows 11 Pro
      • #33
        Maybe, I am idiot, but you have to at least turn GI on and set the Progressive time to something greater than 1 minute. I keep reading to reset to new default, hit render, and see what happens. Obviously, it'll be dark and grainy as heck.
        Bobby Parker
        phone: 2188206812
        • Ryzen 9 5900x CPU
        • ​Windows 11 Pro
        • #34
          Was this with Progressive? or Adaptive? Did you use BF+LC or IRR+LC. If IRR+LC, did you use the default?
          Originally posted by eyepiz View Post
          It's actually simpler.. Lele's cheatsheet sumed it up pretty good. Just reset Vray and give it a go. The scene I was testing today ended up with a sweet spot of 1/48 and noise threshold of 0.006 for as good of result of an optimized 3.2 scene.
          I did take me about an entire day to get used to the system, it wasn't faster in the end but a hell of alot simpler not having to do the whole balancing act with subdivs that was so time consuming before.
          I'm happy and sticking with the new auto algorithm for now on.
          Bobby Parker
          phone: 2188206812
          • Ryzen 9 5900x CPU
          • ​Windows 11 Pro
          • #35
            Tested on Evermotion scene Archinteriors vol. 40 scene 008.
            Defaults, Adaptive, IM+LC, Max Ray intensity off Reinhard burn value 0.2
            Adaptive Image sampler: 1/48
            Color threshold 0.008
            Render time: 9:30min
Name:	Test Scene 3.3.RGB_color.jpg
ID:	859267Click image for larger version
Name:	Test Scene 3.3.VRaySampleRate.jpg
            Thomas A. Edison
            • #36
              What was the resolution and what are your computer specs? I had to cancel mine, after waiting 12 hours for an image that was only 2/3 done.
              Bobby Parker
              phone: 2188206812
              • Ryzen 9 5900x CPU
              • ​Windows 11 Pro
              • #37
                1400x1050
                Dual 14 core 3ghz Xeon System 64 of gigs ram.
                Thomas A. Edison
                • #38
                  Okay, thanks. I am rendering this kitchen out at 4K and I have 1/2 the machine you have. Mine is a XEON Dual Quad core (24 cores) with 32G RAM and it's 2.6ghz processor. So, mine should technically take 8X longer, which would still be killer. I'm testing it now.
                  While I have you on the line. When you reset your render engine, to get the new defaults, is your GI off and Progressive set at 1 minute? If so, everything is good here. If not, something isn't correct for me.
                  Bobby Parker
                  phone: 2188206812
                  • Ryzen 9 5900x CPU
                  • ​Windows 11 Pro
                  • #39
                    Yes, I had to change the Progressive to Adaptive, I can't remember if I had to turn on GI but I probably did since I had to set it for IM/LC.
                    Thomas A. Edison
                    • #40
                      Okay, I am not loony then.
                      If GI has to be on, I wonder why it's not on by default. Also, why would the Progressive be set at 1 minute? I am sure there is a reason. Maybe, Progressive time limit should be 0, along with the memory allocation.
                      Bobby Parker
                      phone: 2188206812
                      • Ryzen 9 5900x CPU
                      • ​Windows 11 Pro
                      • #41
                        I got some awful GI splotches, in the shadow area, with IM+LC, however, it was fast Using BF+LC does a much better job, but is slower.
                        [ATTACH=CONFIG]27603[/ATTACH][ATTACH=CONFIG]27604[/ATTACH]
                        Bobby Parker
                        phone: 2188206812
                        • Ryzen 9 5900x CPU
                        • ​Windows 11 Pro
                        • #42
                          I have not installed the update yet, ( I am in the middle of a project) but I have a quick question.
                          In this new workflow do you need to set Global Sub Mult. to 0 to eliminate any per material/light subdiv. or should I leave it at default 1??
                          When I merge object made by others, they come with different values for glossy and specs, should I reset those to default 8 or global sub Mult. will take care if it as 3.2 does?
                          • #43
                            V-Ray handles all that now. You can bypass it, however, it's that way by default.
                            Bobby Parker
                            phone: 2188206812
                            • Ryzen 9 5900x CPU
                            • ​Windows 11 Pro
                            • #44
                              For me, so far, setting primary engine to adaptive and GI to BF+LC is good; leaving everything as default.
                              Bobby Parker
                              phone: 2188206812
                              • Ryzen 9 5900x CPU
                              • ​Windows 11 Pro
                              • #45
                                Thanks,
                                I can't wait to try out this latest update.
                                BTW Bobby, you latest work show a great improvement, they look really good. congrats!
