Cheatsheet: How to get a Cleaner image with SP3
  • #76
    I have converted it awhile ago, so there is no going back.
    Well, you could re-install 3.2 and do it that way if you have to. For everyone else, it might be a good idea to back up a copy of your project's last 3.2 session before converting to 3.3, just in case you do need to go back.
    I have reset the renderer several times, so that should be good. Also, I have merged everything into a clean MAX session, but it didn't make a difference.
    And did you change to the Adaptive sampler, with Min subdivs=1, Max subdivs=24 and Color threshold=0.01?
    If this doesn't fix it, perhaps Vlado or Lele could jump in here and take a look at your file and see what is going on.
    -Alan
    • #77
      I have converted it awhile ago, so there is no going back. I have reset the renderer several times, so that should be good. Also, I have merged everything into a clean MAX session, but it didn't make a difference.
      Do you use skylight portals by chance? If you're using HDRI, they eat up a LOT of time and aren't needed.
      David Anderson
      www.DavidAnderson.tv
      Software:
      Windows 10 Pro
      3ds Max 2024.2.1 Update
      V-Ray GPU 6 Update 2.1
      Hardware:
      Puget Systems
      TRX40 EATX
      AMD Ryzen Threadripper 3970X 32-Core 3.69GHz
      2X NVIDIA GeForce RTX 3090
      128GB RAM
      • #78
        Yes, an HDRI with light portals is my setup.
        Bobby Parker
        www.bobby-parker.com
        e-mail: info@bobby-parker.com
        phone: 2188206812
        My current hardware setup:
        • Ryzen 9 5900x CPU
        • 128gb Vengeance RGB Pro RAM
        • NVIDIA GeForce RTX 4090 X2
        • ​Windows 11 Pro
        • #79
          -Alan
          I tried almost everything. The defaults you mention and every other setup you can think of. I spent the entire day yesterday trying to get it to work. Last night, about midnight, I reset everything and hit render (Adaptive sampler, with Min subdivs=1, Max subdivs=24 and Color threshold=0.01). This morning, I woke up to about 1/3 of it done.
          Bobby Parker
          phone: 2188206812
          • Ryzen 9 5900x CPU
          • ​Windows 11 Pro
          • #80
            Why Max subdivs=24? Have you tried going higher? What happens? From what Lele had said, you can go way up on that to speed things up. For my particular scene, I'm playing around with max subdives=100 and Color threshold=.01 with very little noise and no red in the image sampler. I'm sure I could come down on max subdivs, and probably will, but it sure isn't like the old days where it's set at 12 or 14. I would also turn off your portals and see if that helps. Everything I've been reading says that they're really not needed with using HDRI. From what I'm seeing, that seems to be true because of the Render mult: (HDRI intensity) and Inverse gamma: (contrast) adjustments of the HDRI.
            David Anderson
            Software:
            Windows 10 Pro
            Hardware:
            Puget Systems
            TRX40 EATX
            128GB RAM
            • #81
              I started with MAX Subdivs at 100 and Noise Threshold at .01. I went lower on the Noise Threshold until I didn't have noise and down on MAX Subdivs until I got I was mostly blue with green/red on details. I think 48 and .003 was where I ended up. I'll try turning off the portals and I'll report back.
              Bobby Parker
              phone: 2188206812
              • Ryzen 9 5900x CPU
              • ​Windows 11 Pro
              • #82
                I cranked up my HDRI slightly with a Render mult: 2 and .75 on Inverse gamma. Of course it will be different for you, but yes, I think you'll find the portals will save time on that.
                David Anderson
                Software:
                Windows 10 Pro
                Hardware:
                Puget Systems
                TRX40 EATX
                128GB RAM
                • #83
                  Each HDRI is different, but with this one, I have it at 1 and my inverse gamma at .9
                  Bobby Parker
                  phone: 2188206812
                  • Ryzen 9 5900x CPU
                  • ​Windows 11 Pro
                  • #84
                    Well, at this point I would ask that Vlado or Lele took a look at your file...it seems that they worked very hard on the new sampler and that they wanted it to help, not hinder.
                    I'll do more testing here, as well...
                    -Alan
                    • #85
                      I deleted all my portals and things see to be speeding up. I have always used light portals with my hdri's; who would have guessed it would cause so much headache. Now more than ever, but I was probably always rendering slower than I should have been. Thanks for the tip!
                      Bobby Parker
                      phone: 2188206812
                      • Ryzen 9 5900x CPU
                      • ​Windows 11 Pro
                      • #86
                        I've also discovered that if I delete all of the glass in my windows except for what's visible on camera, that speeds things up too. You may already know that though.
                        David Anderson
                        Software:
                        Windows 10 Pro
                        Hardware:
                        Puget Systems
                        TRX40 EATX
                        128GB RAM
                        • #87
                          this one is good, but I'll keep that in mind for others. Again, thanks.
                          Bobby Parker
                          phone: 2188206812
                          • Ryzen 9 5900x CPU
                          • ​Windows 11 Pro
                          • #88
                            -Alan
                            Alan, I find these settings to leave quite a bit of noise. I had to bring down the Color Threshold to 0.003 and because VRay directs the sampling around, some areas ended up nice and some with quite some noise. Any other settings you change around?
                            • #89
                              Was the noise in the red or blue? The first post in this thread tells you what to do.
                              Bobby Parker
                              phone: 2188206812
                              • Ryzen 9 5900x CPU
                              • ​Windows 11 Pro
                              • #90
                                If the SampleRate shows blue in the noisy areas, lower noise threshold
                                If the SampleRate shows red in the noisy areas, raise max AA subdivs
                                Bobby Parker
                                phone: 2188206812
                                • Ryzen 9 5900x CPU
                                • ​Windows 11 Pro
