Great. How do I download it? I log in with my username at nightlies.chaosgroup.com but the "Latest Builds" folders are all empty.
Bump mapping makes objects look faceted
Aleksandar Mitov
www.renarvisuals.com
office@renarvisuals.com
AMD Ryzen 9 9950X 16-core
96GB DDR5
Originally posted by Alex_M View PostGreat. How do I download it? I log in with my username at nightlies.chaosgroup.com but the "Latest Builds" folders are all empty.Dmitry Vinnik
Silhouette Images Inc.
ShowReel:
I am getting all sorts of weird things with normal maps and i also still have issues whe i set the bump map to high value it always does a hard edge when lit from the side...on the lates vrayMartin
http://www.pixelbox.cz
Originally posted by PIXELBOX_SRO View PostI am getting all sorts of weird things with normal maps and i also still have issues whe i set the bump map to high value it always does a hard edge when lit from the side...on the lates vray
Please check my post here
http://forums.chaosgroup.com/showthr...l-map-problems
This needs to get fixed quite badly because in max 2017 you can no longer use standard normal bump whan renderign with vray.
You wont even be able to see the normal bump on the list of the general maps rollout Martin
Maybe someone said it, but do you put right gamma in bitmap loader, when loading normal maps, if you are using linear workflow?AMD TR 7980X, 256GB DDR5, GeForce RTX 4090 24GB, Win 10 Pro
2D | 3D | web | video
jiri.matys@gmail.com
https://gumroad.com/jirimatys
https://www.artstation.com/jiri_matys
https://www.youtube.com/channel/UCAv...Rq9X_wxwPX-0tg
https://www.instagram.com/jiri.matys_cgi/
https://www.behance.net/Jiri_Matys
https://cz.linkedin.com/in/jiří-matys-195a41a0
Like Jiri wrote.
When you are using linear workflow bitmaps get loaded at a gamme value of 2.2 usually. But for normal maps, as much as I understood it, vray expects a gamma value of 1.0. So when you are loading normal maps you might set the input gamma value to 1/2.2 manually wich equals roughly 0.4545...
Doing that, I did not see anymore problems regarding normal maps.
Still getting bad faces on regular bump mapping with high settings on vray 3.40.2 though. But that image from 3.45 nightly looks promising
I dont know if this is related but try this:
in max 2017 with vray, make a simple sphere primitive (dont change to editable poly) and hit render. After render change segments of the sphere. It makes sphere faceted and completely wrong even in viewport.
Its really weird. And I try to do this with scanline renderer and its ok, do this only with vray!AMD TR 7980X, 256GB DDR5, GeForce RTX 4090 24GB, Win 10 Pro
Originally posted by Jiri.Matys View PostI dont know if this is related but try this:
It kind of makes you wonder how is that even possible. Why would anyone touch sphere primitive's code
Its do this only with vray as renderer, with other not. And happened with all primitives (I try only three, but I think that).
And Autodesk dont repair it even with SP2, right?AMD TR 7980X, 256GB DDR5, GeForce RTX 4090 24GB, Win 10 Pro
Any news on this? Kind of bugged out with the whole faceted, sharp shadow bump thingy
The issue from the original first post is long solved. I haven't looked at the rest of the posts, as I got totally confused due to multiple people talking about different issues.
VladoI only act like I know everything, Rogers.
