Originally posted by vlado
View Post
Bump mapping makes objects look faceted
Originally posted by jp3d81 View PostI can´t use normalmaps with displacement in subdivision mode.
VladoI only act like I know everything, Rogers.
Sorry for digging out this old thread but I'm still getting sharp shadows on subdivided objects when I use bump maps. Any way to avoid this? It looks a bit ugly and I really can't not use bump otherwise the grass looks too "flat". Please check the images below:
Aleksandar Mitov
www.renarvisuals.com
office@renarvisuals.com
AMD Ryzen 9 9950X 16-core
96GB DDR5
Same. What if you use a normal map, does it happen then too?
Originally posted by Vizioen View PostSame. What if you use a normal map, does it happen then too?Aleksandar Mitov
96GB DDR5
Originally posted by davision View PostI don't know if this is the same problem I've had in the past or not -- but try putting a Turn to Poly modifier on the object and see if it still creates the sharp shadows....Aleksandar Mitov
96GB DDR5
