Bump mapping makes objects look faceted
  • #31
    VRaySun and VRaySky - vertical offset setting for the skydome, control of the ground blending;
    That s a small feature but man...
    I love pg skies but there is always the problem that we see the black horizon due to the cut in the HDR.
    So glad to have that option . Thanks !
    Gil Guminski
    cynaptek.com
    • #32
      exposure control is back!
      Architectural and Product Visualization at MITVIZ
      http://www.mitviz.com/
      http://mitviz.blogspot.com/
      http://www.flickr.com/photos/shawnmitford/
      i7 5960@4 GHZm, 64 gigs Ram, Geforce gtx 970, Geforce RTX 2080 ti x2
      • #33
        I don't see how the two are related?
        A.
        www.digitaltwins.be
        • #34
          Maybe I missunderstood but if a vertical offset of the texture is now possible I can get more sky and less black.
          I don't have to try to hide it someway.
          Gil Guminski
          cynaptek.com
          • #35
            Yeah... thought you could already change the rotation and offsets of a spherically mapped HDMI.
            • #36
              Yes but if you have an animation in the middle of the ocean with no island. That won't work.
              Gil Guminski
              cynaptek.com
              • #37
                The changes are related to the VraySun and VraySky skydome, so nothing to do with the VrayHDRI map. Offset, tiling, is already possible. If you want less black I suggest adjusting the tiling (never tried it, but should work).
                Edit: just tried, it doesn't work But you might just stretch or paint some extra sky in photoshop if necessary.
                Edit2: what might work without photoshop is use Crop/Place and set Crop in the V direction to something small like -0.02. But that results in black hole at the top, so not really ideal.
                A.
                www.digitaltwins.be
                • #38
                  This problem still appears in Vray 3.40.02? I've got a normal map that I've got too boost to get a better definition but I'm getting faceted polygons instead
                  Aleksandar Mitov
                  www.renarvisuals.com
                  office@renarvisuals.com
                  AMD Ryzen 9 9950X 16-core
                  96GB DDR5
                  • #39
                    make sure you are not gamma correcting the normal map. It should be set to 1.0
                    Dmitry Vinnik
                    Silhouette Images Inc.
                    ShowReel:
                    • #40
                      Yes, texture gamma is 1.0, not 2.2. That's actually the first thing I checked.
                      Aleksandar Mitov
                      96GB DDR5
                      • #41
                        can you post that leaf with its normal map?
                        Dmitry Vinnik
                        ShowReel:
                        • #42
                          Sure, please see attached.
                          Aleksandar Mitov
                          96GB DDR5
                          • #43
                            I have a very recent nightly build for vray 3.45.01
                            It appears to render properly with default vray settings.
                            Dmitry Vinnik
                            ShowReel:
                            • #44
                              It does look better. How safe is to use a nightly build? Any problems using it in production?
                              Aleksandar Mitov
                              96GB DDR5
                              • #45
                                Well I use it without issues.
                                Dmitry Vinnik
                                ShowReel:
