New feature ideas 2
This is a sticky topic.
  • #16
    Light Cache for GPU IPR
    Because Vray GPU uses BF+BF in IPR mode, its is often noisey and slower than just re-rendering the image. Also the GI results can be quite different between the two.
    • #17
      Bump settings to be more consistent between Vray CPU and Vray GPU
      • #18
        When dragging bitmaps into 3ds max , have the option to automatically import them as Vray Bitmaps instead of the standard 3ds Max Bitmap.
        • #19
          Performance improvements on matte shadow + alpha, and matte shadow + reflection + alpha in Vray... It really is VERY slow, and the sampling quality is really bad. Pardon the comparisons, but Corona and fstorm are way faster in this regard.
          • #20
            Being able to load multiple bitmaps/vray bitmaps at once in the Vray Multisubtex node. Similar to the Multitexture plugin.
            https://cg-source.com/MultiTexture
            • #21
              The option in Vdenoise tool to make the output denoised EXR file with OR without render element (to reduce the exr file size if i had already the render element saved in jpg)
              • #22
                Adding the option to have all render elements affected by layers stack in the VFB when saving all image channels into a single file.
                • #23
                  Support for SSS in VrayMtl with GPU.
                  • #24
                    A quick way to mirror the image in the VFB buffer. Great way to check composition.
                    • #25
                      A quick way to make the image monochromatic. There was a button in the old VFB buffer. This was great to see the contrast in the image.
                      • #26
                        An option to respect refraction when using the material override or the ipr debugging lighting too.
                        • #27
                          I wonder if there is a way or even if its possible to blend assets together like this in 3ds max:
                          https://www.youtube.com/watch?v=QErp...ature=emb_logo
                          https://quixel.com/blog/2020/1/22/bl...-assets-in-ue4
                          https://www.youtube.com/watch?v=8LQF...ature=emb_logo
                          • #28
                            An intuitive vertex blending system that takes height data into account (i.e., painting dirt into cracks of the material). I know you can mimic this behavior with masks and but it will not nearly as procedural or intuitive as having a built in system to handle such data.
                            https://quixel.com/blog/2020/10/13/u...blend-material
                            • #29
                              Standalone VFB (Like Corona Image Editor) + Sequence playback
                              There used to be a product called PDPLayer.
                              OakCorp Japan - Yuji Yamauchi
                              oakcorp.net
                              v-ray.jp
                              • #30
                                Selective texture map resizing based on vray object property or sets.
                                e: info@adriandenne.com
                                w: www.adriandenne.com
