V-Ray/Blender 2.6
This is a sticky topic.
  • #31
    Re: V-Ray/Blender 2.57
    1.
    ok we have camera's perpective shift, but where is straight shift x y ? )
    2.
    DOF is probably broken - this is what i get when choose dof with pointing object (rendering doesnt start)
    (When i choose dof without pointing object - vray renders but doesnt take into account DOF settings.):
    File "/Applications/Blender/35920GIT/blender.app/Contents/MacOS/2.56/scripts/startup/vb25/render_ops.py", line 918, in render
    vb25.render.render(self, scene)
    File "/Applications/Blender/35920GIT/blender.app/Contents/MacOS/2.56/scripts/startup/vb25/render.py", line 1890, in render
    err= write_scene(bus)
    File "/Applications/Blender/35920GIT/blender.app/Contents/MacOS/2.56/scripts/startup/vb25/render.py", line 1704, in write_scene
    write_frame(bus)
    File "/Applications/Blender/35920GIT/blender.app/Contents/MacOS/2.56/scripts/startup/vb25/render.py", line 1677, in write_frame
    PLUGINS['CAMERA']['CameraPhysical'].write(bus)
    File "/Applications/Blender/35920GIT/blender.app/Contents/MacOS/2.56/scripts/startup/vb25/plugins/CameraPhysical.py", line 379, in write
    focus_distance= get_distance(ca,camera.data.dof_object)
    NameError: global name 'ca' is not defined
    im just finishing a winter figure (all in vb 2.57 RC0 build + PS)
    here's full render: viewtopic.php?f=5&t=525
    and here some splash proposals:
    mat tests>
    render tests>
    • #32
      I'll fix everything this weekend.
      andrei.izrantcev@chaos.com
      Support Request
      • #33
        Originally posted by FB3000
        Hi Yaroslav,
        I just wanted to ask U if these different results (yaf/vray) with IES arent caused by different shutter settings in physical camera?
        I mean does shutter speed shouldnt be longer to achieve result from yaf renders?
        Hi, and thank U.
        YaR has no physical camera...
        • #34
          How long do we have to submit splash proposals?
          I'm in the middle of several projects so I can't test the new build just yet, but when I finish these up I'll be sure to start testing away
          • #35
            StompinTom, util final 2.57 release plus few days.
            Support Request
            • #36
              Hi Andrey,
              I stumbled upon the following during the last couple of days:
              SSS material:
              1. - prepass blur is limited to 1.0, while it shouldn't be.
              2. '' - single scatter subdivisions (still) limited to 8
              3. "Cutoff threshold" should be under "Specular layer" because it (correctly) affects the specularity tracing threshold and not Single scatter
              When using particles hair:
              1. particle steps are not taken into account and the hair is rendered as straight lines regardless of B-Spline interpolation on/off switch. See the attached thumbnails for illustration.
              2. Particle textures panel is completely empty, so no textures can be assigned to particle systems
              • #37
                Use "Segments" to make hair smoother.
                Support Request
                • #38
                  I used them, set them to 9, which is rather high for Blender itself. And if I have to rely only on this, without interpolation it's bad, not only because the result will never be as smooth as it should be, but because high values require a lot move CPU power. And please tell me that this can be edited somewhere in the exported scene post-factum, without having to do all the hair editing and combing every strand into place again!
                  • #39
                    Script uses MayaHair plugin and it takes data from Blender as is. You could write your own hair geometry implementation and interpolate Blender data...
                    Support Request
                    • #40
                      Crap! That means one month lost time for me. End of my V-Ray for Blender story.
                      • #41
                        zmurdz, shit happens =) Lets look at the bright future =) May be one day everything will be as we want it ) I'm doing my best...
                        Support Request
                        • #42
                          @smurdz
                          This is really strange, so why dont U just checked how hair works in VB before u started this serious one month work?
                          I dont think its Vb 25 only problem - U can't just bake hairs into real mesh so this is also blender's lack of feature which is known problem when U export to other render engines or game engines.
                          Some people write about partially solving problem solutions so check this:
                          http://vimeo.com/4407273
                          http://blenderartists.org/forum/showthr ... air%20mesh
                          or this:
                          http://www.yafaray.org/documentation/tu ... particles1
                          So maybe it will help U,
                          mat tests>
                          render tests>
                          • #43
                            zmurdz, could you send me your scene (or part of it) - this looks like some specific bug - look at my hair:
                            Scene: http://www.pasteall.org/blend/5989
                            Render:
                            Support Request
                            • #44
                              ok i kill me but i cant make it render this hair - it renders only the emiter, i tested it on build with updated 2 days ago script, heres my file with saved settings:
                              http://dl.dropbox.com/u/19725436/vb_bug ... l_ps.blend
                              mat tests>
                              render tests>
                              • #45
                                bdancer, I tried your scene and can't get any hair, same as FB3000 - only the emitter sphere....
                                bdancer, can you post a render of your hair with 9 segments - just to compare better, because this is what I am using now?
                                When you say you are using maya hair plugin is this what you are reffering to? - http://www.spot3d.com/vray/help/maya...fur_params.htm
                                Here is my hair: http://www.pasteall.org/blend/5993
                                P.S.
                                @bdancer and FB3000 - you are both right - shit happens, and it is my fault that I didn't checked everything before starting this. And I don't blame anybody here, nor do I have any bad feelings, just on the contrary - thanks for the help. I'll try the mesh-curves-mesh method, it may be a workaround.
