Clay Garage
garage taipa.
modeling and rendering by me :slight_smile:
in the interior of Brazil, in the past, houses were made of clay, known as clay
houses, so I created a garage in this style
Nicely done! The grass looks great. How did you achieve that? Skatter?
do not. this is Enscape. :slight_smile:
there are two faces, one with earth and the other with grass.
the face of the grass I was adjusting the height of the object until I reached the desired point
Wow, great trick! Amazing results.
Actually, that makes me think… Right now, the Enscape grass size scales the whole grass blade. But if you want to show just an earlier growth process, you might want to move it into the ground without scaling it (as you did). Interesting!
O que outras pessoas estĂŁo dizendo
thanks.
“always use your imagination” ^^
brilliant
THANKS
