I use 3dsmax 2024 and I like to use mountain backgrounds with CoronaLightMtl and I use opacity map to cut out the shape of the mountains to use the sky of CoronaSky, but when using the Corona Sky “Volume effect” it affects the material where nothing should appear because it is 100% opacity… Fixing this would be important… Thanks
can you share the scene? You can also share it privately by starting a ticket with us: https://support.chaos.com/hc/en-us/requests/new
Note: you can also share images showcasing the problem (renders, viewport screenshots, material setup) here so that we can understand better what is going on
I was able to reproduce this issue on my end. I have logged this in our system.
(Report ID=CMAX-1260)
For now, you can use corona physical material with self-illumination or use Corona color correct to increase exposure of your backplate as a workaround.
But… how would increasing exposure of the backplate help if the area with 0% opacity would still render brighter for anything behind it?
I guess the volume effect needs to be looked at in general, it’s producing unexpected results in too many cases, especially since problems have been reported for quite some time now.
this issue is only happening with Corona light mtl and not with Corona physical material. You can test it. & there are other cases as well where using volume effect is breaking things but those are different issues. In general, most of these cases are reported and are being looked at.
What I meant is that it doesn’t seem logical to suggest increasing exposure in a CC node specifically since the plane in front will still render brighter. So if you brighten the background up in CC, it’ll render even brighter, still.
Sorry, I don’t understand. I think we are discussing two separate things. Can you explain why would “plane in front will still render brighter” with Corona physical material?
This issue has been fixed in the newly-released Corona 16 preview build and the fix will be included in the final Corona 16 release: Chaos Corona 16 for 3ds Max - Previews (Daily Builds) Changelog - #4 by AramAvetisyan
Please try it and let us know if everything is working as expected. Thanks!
