licensing issue, can't generate .wbc file
I can’t generate a .wbc file for dongle reprogramming. It always comes up with this error message:
Failed!
There was an error while trying to obtain the context (-100). Contact Chaos Software to resolve the problem
How do I get around that?
I’m on Mac OS X 10.9.3.
Cheers,
Sebastian
I’ll get someone from the support guys to help, I know they’ve come across this before. Bit of a bummer that this comes in on Friday night… In the meantime, if it’s possible, you can generate the .wbc file on another machine (Windows or Linux; Windows generally is more reliable).
Thanks for the reply! Was easy in the end, just had to run the vrlservice with root permissions.
Cheers
We are glad to hear you sorted it out.
Feel free to contact us again if you have any issues.
You can get a license server from the 2.4.02 build (or 3.0 beta 2 if you have access). This error should be fixed there. AFAIK, it was not root related, but you must run vrlservice from the console to work around the -100 error. The new vrlservice should work fine even if launched from the GUI.
