Could anyone please tell me why I’m getting multicoured splotches on my renders. It seems to happen more on reflective surfaces.
I’m using version 1.47.03
you can show an image so we know what your talking about however sounds like raytrace map or material involved somewhere
Could you tell me how to upload an image. Not sure how to
take a look at this thread, it gives links to some free host, where you can upload your files.
http://www.chaosgroup.com/forum/phpBB2/viewtopic.php?t=12769
nikki Candelero
Finally have somewhere to host my image without being blocked at work.
www.charliefarlie.co.uk/temp/tst3250.jpg
I seemed to have narrowed the problem down at bit i think. The animation is 4000 frames so I am trying to save the vrmap (multiframe incremental) every 20 frame over the length. It seems to be related a bit to anything with reflection but when the solution for the vray starts to reach the end of the animation the dialogue box reports errors of overbrightness on loads of materials and then when rendering using the saved vrmap it renders out like the attached example???. If I then render that frame in single frame mode it comes out fine. really baffled.
:shock:
do u have any raytraced material in that scene?
yes I do although that particular image only had a small amount on the table and chairs
raytrace materials are not compatible with vray. use either the vraymaterial or if your using the raytrace map the vraymap
Regards,
Thorsten
Sorry, I am using a vray material with reflection but i’m starting to lean towards more of a memory issue, since it only happens when computing a solution for a vrmap using multiframe incremental on a number of frames. Is this an issue with vray?
u can test i t for ur self:
use a vraymaterial in the overridematerial slot rerender and see for ur self!
1 thing is for sure vray does not go well with raytracing materials!
Still rendering with splotches
can you provide a sample of the scene that exhibits the issue?
I’m thinking percy meant the actual scene file not just an image…
Yeah he was talking about the max file itself.
Are there any errors in the vray log file.
It really does look like you have something incompatitble in there. But assume you are using the material override properly then it doesnt look like its a material problem atleast
The problem is, is that its 70MB. Which may be a bit difficult. Could you please tell me, is there a material overide button or is it just reducing the intensity of the material?
It definately only happens when I use multi frame incremental.
THe override material slot is in the Vray:Global switches rollout in the render panel
Make a new default vraymtl in the material editor tick the box next to the override material and then drag the default vraymtl onto the button there.
That will render your scene with a default vraymatieral applied to everything, so if you have glass windows they wont be glass anymore and they will block the light so best to just hide them (the glass panes).
If you have ANY max default raytrace materials (includes the 3dsmax architectual materials), make sure you remove them.
In the VRay::GLobal switches - there is the Override material slot.
Add a fresh new VRayMtl there and see if those come again.
nikki Candelero
Maybe next time Nikki
hehehe
:twisted: :twisted: :twisted:
Damn, I have to improve my speed typing.
nikki Candelero
