My Rhino 8 could not open Enscape 4.0
I already installed Enscape on my Mac. Enscape 4.0 Seems to support Rhino8 but I couldn’t find even the Enscape start command in Rhino, What is the problem?
Thanks.
Hi @korphai , and welcome to our Forum.
Please kindly check out the following knowledgebase article here:
https://learn.enscape3d.com/blog/knowledgebase/enable_enscape-mac-rhino/
If you cannot enable Enscape within Rhino 8.3+ (Enscape requires at least Service Release 3 to be installed) then please also try the clean re-install as also detailed in the article:
Thank you in advance for your cooperation.
