Update 1.8.5 and LiveLink
After the last update I’m having a lot of problems with unexpected crashes via livelink, the connection via livelink isn’t working properly either, I have to click the ‘render animation’ button several times.
Another problem detected is that vantage is rendering the same frame twice, it seems to be a problem in the latest version of vray.
https://drive.google.com/drive/folders/10nKv2FTmJ7hJB7pOXhKvdmxDOpSBBwAm?usp=share\_link
I downgraded to Vray version 6.10.04 and the same frame rendering issue was resolved, I used vantage 1.8.5
Probably the problem is in vray version 6.10.06, which also seems to be slower to start the link and send the geometry to vantage.
Vantage 1.8.5 is working, but I still have problems with crashes, example: sometimes when the livelink is started, Vantage crashes at the time of “Scene Ready”
I also had twice problems with crashes in the middle of rendering an animation.
In all cases, it’s Vantage that crashes, not 3dsMax ?
Do you think it’s scene specific or it happens on any scene ?
In any case, it will be helpful if you could send us one of the scenes which has crashed Vantage.
Greetings,
Vladimir Nedev
Hi, Vladimir.
I tested some more old and new scenes and the problem persists only in version 1.8.5 of Vantage, in version 1.8.4 everything runs fine
I made a screen recording and you can see that sometimes the scene opens and sometimes it doesn’t.
https://drive.google.com/file/d/1CdWGWweOsoBzDRZ9cK\_YpVrdKRIeFa8h/view?usp=share\_link
When this happens, do you see new “Vantage_b*_p*.dmp” files in your %temp% folder ?
Greetings,
Vladimir Nedev
Hi pablo_vinicius,
Unfortunately I am unable to reproduce this. Can you send us the scene so we can try it on our end? You can upload your scene to wetransfer / gdrive / dropbox / mega, etc , use the help center (https://support.chaos.com/) and link this forum thread.
Alexander​
Hi guys,
Since I’ve updated to 1.8.5 I’m experiencing some lag issues in both 3ds Max (2023) and Vantage UI when I’m working live-link.
This occurs every time I made something in 3dsmax; add a modifier, plug a map into a material, modify some parameters, etc…
Basically, every action which requires “to be sent” from 3ds to vantage causes the UI to freeze for like 1 sec.
Luckily I’m not experiencing any crashes.
This was not happening with the previous versions.
I have an RTX3090 with the 531.61 Driver.
Thanks!
Can you test the exact same scene in a previous Vantage version and confirm that the issue was not present ?
Have you updated V-Ray for 3ds Max ?
The issues you are describing sound like something happening in V-Ray for 3ds Max itself.
Greetings,
Vladimir Nedev
Hi Vladimir,
I’m currently working on a couple of scenes that were working really fine with the previous version.
And yes, Vray 6 is updated to the 1.1
Thanks!
Can you try opening the following file in an editor (in administrator) mode:
C:\Program Files\Chaos Group\Vantage\dcc_scripts\3dsMax\Vantage-LiveLink.ms
and delete the following line
vr.ipr_useRenderState = true
Then save the file.
You will have to restart 3dsMax for the change to take effect.
After that try again if the live link starts working as expected.
Greetings,
Vladimir Nedev
The problem is not in a specific scene, it is in all scenes.
In version 1.8.4 it is working perfectly.
I saw reports in the facebook group about the same problem​
Doesn’t generate any files after crash
I did some procedures that I saw in a similar topic on the forum and apparently the problem of loading the scene by livelink was solved.
The cause of this was the Cosmos.
I will continue testing to see if it happens again.
How did you solve it - by uninstalling Cosmos ?
Greetings,
Vladimir Nedev
I never used cosmos and apparently it had some problem, I just deleted the cpkg.db file in C:\Users\***\Documents\Chaos Cosmos\Packages
I downgraded to Vray version 6.10.04 and the same frame rendering issue was resolved, I used vantage 1.8.5​
Did this really get resolved or maybe it happens randomly ?
Are you still on 6.10.04 ?
I also had twice problems with crashes in the middle of rendering an animation.​
Are these still happening ?
Did you have such crashes before 1.8.5 ?
Greetings,
Vladimir Nedev
I encountered the same issue when using beta version 1.9.7
Not sure if it’s the same reason,
and sometimes it will crash when Vantage displays "Scene Ready"​.
Hi Vladimir.
I did more tests and the crash problem was completely solved after correcting Cosmos, but I still have the duplicate frame problem in vantage version 1.8.5
At first I thought it was a problem with the V-ray version, but I updated v-ray to version 6.10.06 and the problem only happens with vantage 1.8.5.
I made some sample screen recordings, you can see that in vantage 1.8.5 the frame advances and then rewinds.
We are looking into it.
Greetings,
Vladimir Nedev
