Hey guys,
V-Ray 6, hotfix 2 is now available for download from our website.
Build 6.00.08 (V-Ray 6, Hotfix 2) (Aug 10, 2022)
Modified features
VRayBtimap
- Implement Qt UI of VRayBitmap;
VRayBlendMtl, VRaySwitchMtl
- Use native 3ds Max material and map Qt buttons wherever possible;
Bug fixes
V-Ray
- Crash on starting IPR rendering with Forest scene;
- Drag and dropping images onto the VRayBitmap’s bitmap slot stopped working;
- VRayMtl appears black when using SSS translucency and refraction is not white;
- Undo for clear shortmap button is not working for QT based UI;
- Applying 3ds Max Modifier to a simulator/volume grid in volumetric mode prevents it from rendering;
V-Ray, VRayEnmesh
- VRayEnmesh produces wrong results when shaded with VRayTriplanarTex;
VRayEnmesh
- Crash when excluding VRayEnmeshMod object from a light;
VRayInstancer
- Crash on aborting Chaos Scatter creation with V-Ray IPR running;
VRayLight
- Adaptive dome artifacts with VRayScatterVolume material;
VRayMtl
- Opacity renders as solid black with black fog color in V-Ray 6;
- Wrong render of VRayMtl with opacity and fog color;
