V-Ray 6, update 1 hotfix 2 - now available (6.1.2)
V-Ray 6, update 1 hotfix 2 (6.1.2) is now available for download from our website.​
Build 6.10.08 (May 3, 2023)​
New Features
V-Ray, V-Ray GPU
  • Add initial support for RAW render elements in V-Ray GPU
Modified Features
V-Ray
  • Optimize vrscene export for ForestPack and motion blurred Anima assets
Bug Fixes
V-Ray
  • Cosmos auto-downloader should not modify or consider proxy/bitmaps pointing existing files
  • VRayBitmap preview in Max 2024 Viewport is wrong when using Max Color Management
  • V-Ray properties’ values cannot be bulk-changed
  • Render crash with hidden grouped objects added to the light exclude list
  • EULA does not get accepted when a 2-byte character is used in the username
  • Progressive resumable rendering could leave corrupted files in case of a system crash during saving
V-Ray GPU
  • Rendering animation stops in the middle of the “Loading bitmaps” stage
  • Aborting GPU render before rendering might crash
V-Ray Toolbar
  • Chinese text for the Vantage toolbar icons in the English 3ds Max UI
VFB
  • Export of an image with wrong gamma when ICC Display correction is used
VRayMtl
  • User-created proxies created after cosmos asset import, might get overridden on auto-download
