For a little while there has been a weird bug that I have come across. For some reason whenever I use Escape trees and if they are near the edge of the render they either get odd reflections or become white somehow. At first i thought it was fog or something weird with my settings so I reset everything to default and have downgraded the version I have of Enscape several times with no success. I noticed when i change the quality of the render to draft it goes away. If I point the camera lower away from the trees the white edges go away. I didn’t know if anyone else was having this problem as well? I tried to find it in the forum but couldn’t find a discussion on this topic. Hopefully one of you can point me in the right direction. Thanks!
Here is the corner of a project I am working on where the trees along the bottom and the right edge have been washed out.
If I move the camera slightly lower the white goes away except for the tree on the lower left which is near the edge.
Here is the same area when i reduce the quality to draft.
