WIP interior (bathroom)
Here is an almost delivered rendering from a bathroom.
C&C are welcome!
thanks
interesting, u make the box kind of render using clipping planes?
Actually I never added the front walls.
I mixed HDR lighting and Vray lights with very low values in order to get an aproximation of the amount of light i would get from the missing walls.
thanks!
Nice rendering - good technique to see a small space!! Congrats!!
so are those lights, the ceiling lamp and the 2 mirror ones really serving any purpose in lighting the scene or are they just there to act like they are lighting?
Nice scene. Very interesting way of doing a small room.
thanks for the comments
the three lamps are the main sources for direct lighting, the secondary lights (vray light and HDRI) only contribute a small part in the indirect lighting. Also there is some SSS in the lamps body.
one particular issue I found in this secene is that the environment color had a remarkable influence over the reflections. it really helped a lot working on a night shot.
cheers!
nice image! i like the dark reflexions but i do not understand very wel the lower part of the towel
regards
Very nice rendering, I think maybe you could try increasing the contrast a little..
Another thing that i would suggest is giving the walls, roof and floor some thicknes, like a cut..This would make the image a little moew “convincing”
-Tom
Did you use photometric lights in the bathroom?
I tested the scene first but i liked more the result when i used vray lights.
besides i could create some SSS effect on the lamp.
cheers!
