Scene Gone Crazy
  • #76
    If it doesn't work for you, I'll send you the file I made doing it.
    - Geoff
    • #77
      Nope, it didn't work. Ugh!
      Bobby Parker
      www.bobby-parker.com
      e-mail: info@bobby-parker.com
      phone: 2188206812
      My current hardware setup:
      • Ryzen 9 5900x CPU
      • 128gb Vengeance RGB Pro RAM
      • NVIDIA GeForce RTX 4090 X2
      • ​Windows 11 Pro
      • #78
        I think I might have gotten it. I Started merging things in smaller chunks. I got to a series of elements that started with 'arch...' When I merged those elements, all I saw where the gizmos, but no geometry. That wasn't the smoking gun because all that meant was the geometry wasn't where the gizmo was, which isn't to uncommon. However, I started over and merged everything except the 'arch...' stuff and all seems good. Heck, that was a day I'll never get back!
        Bobby Parker
        phone: 2188206812
        • Ryzen 9 5900x CPU
        • ​Windows 11 Pro
        • #79
          Just a follow up. All is good and I am almost done with the scene. I guess I didn't take the merge one-by-one until I find the culprit very seriously, because I couldn't imagine bad geometry could do such a thing. This was probably the issue with the VFB and Everrmotion merges, too.
          Bobby Parker
          phone: 2188206812
          • Ryzen 9 5900x CPU
          • ​Windows 11 Pro
          • #80
            New project and same thing. This time I imported a 3DS MAX that was modeled in MAX 2014; nothing else.
            Bobby Parker
            phone: 2188206812
            • Ryzen 9 5900x CPU
            • ​Windows 11 Pro
            • #81
              When I open the scene again the camera vertical shift is gone and I can't right mouse click to remove it. Also, when I delete the camera, all is good. I am using VRay 3 and a VRay camera.
              Bobby Parker
              phone: 2188206812
              • Ryzen 9 5900x CPU
              • ​Windows 11 Pro
              • #82
                Here is a screen grab showing how it looks when I re-open it.
                Bobby Parker
                phone: 2188206812
                • Ryzen 9 5900x CPU
                • ​Windows 11 Pro
                • #83
                  Hide and un-hide your cameras
                  • #84
                    That doesn't help. When I open the scene up again and the vertical is wrong, I can uptick the Vignetting and it corrects itself.
                    Bobby Parker
                    phone: 2188206812
                    • Ryzen 9 5900x CPU
                    • ​Windows 11 Pro
                    • #85
                      Here is the new scene, which is a simple building shell.
                      https://files.acrobat.com/a/preview/...8-f7d044552dbd
                      Bobby Parker
                      phone: 2188206812
                      • Ryzen 9 5900x CPU
                      • ​Windows 11 Pro
                      • #86
                        Back to the madness!!!! Again, copy/paste something from an Evermotion scene. It started happening; I didn't even save the file and now it is permanently baked into the scene.
                        Bobby Parker
                        phone: 2188206812
                        • Ryzen 9 5900x CPU
                        • ​Windows 11 Pro
                        • #87
                          So if I understand correctly, you merged something in a file from evermotion, the sh*t hits the fan, you don't save. You reopen the file and it's gone loco?
                          A.
                          www.digitaltwins.be
                          • #88
                            Well, I think. Every day a 3pm my project folder gets mirrored and that file was good, so I picked up where I left off there. However, I don't think I saved the file I was working on when I merged the Evermotion stuff, and when I closed and reopened, it was doing that ghosting thing that it does. Regardless, I didn't do any work after my 3pm backup, so this time, no harm done.
                            Bobby Parker
                            phone: 2188206812
                            • Ryzen 9 5900x CPU
                            • ​Windows 11 Pro
                            • #89
                              Have the folks at Evermotion been any help with this issue? Sounds serious enough to at least contact them, after all you're the customer here!
                              • #90
                                Absolutely no support from Evermotion via email or forum
                                Bobby Parker
                                phone: 2188206812
                                • Ryzen 9 5900x CPU
                                • ​Windows 11 Pro
