Scene Gone Crazy
  • #46
    Hide all Proxies (or delete them)
    Hide Forest Pro objects (or delete them)
    Ctrl +A
    Convert all to Mesh
    then Convert all to Poly
    then Reset XForm to everything
    Collapse to Poly
    What do you get?
    Kind Regards,
    Morne
    • #47
      I merged one-by-one and it happens when I merge things called 'mesh'. In the 'mesh' is Evermotion things, and things from the original SU model. So, it's Evermotion or SU, however the other project didn't start in SU. So, it seems to me it is Evermotion. Now, Evermotion used to cause my VFB to freak, which was fixed in V-Ray 3, or that was my understanding.
      Bobby Parker
      www.bobby-parker.com
      e-mail: info@bobby-parker.com
      phone: 2188206812
      My current hardware setup:
      • Ryzen 9 5900x CPU
      • 128gb Vengeance RGB Pro RAM
      • NVIDIA GeForce RTX 4090 X2
      • ​Windows 11 Pro
      • #48
        Even stranger, the Evermotion stuff isn't even a 'mesh' element. However, when I merge the 'mesh' stuff, the evermotion stuff is still there in shaded mode.
        Bobby Parker
        phone: 2188206812
        • Ryzen 9 5900x CPU
        • ​Windows 11 Pro
        • #49
          This is starting to sound very confusing. Attach all objects to one poly with quickattach, and merge that?
          A.
          www.digitaltwins.be
          • #50
            Merged everything but the Evermotion and its still broken. I am trying to merge everything but the SU stuff; I'll report back.
            Bobby Parker
            phone: 2188206812
            • Ryzen 9 5900x CPU
            • ​Windows 11 Pro
            • #51
              Everything but SU... still broken
              Bobby Parker
              phone: 2188206812
              • Ryzen 9 5900x CPU
              • ​Windows 11 Pro
              • #52
                Bobby-I took a quick look at the scene and noticed even after deleting everything (via Ctrl A) you still have a few particle flows in the particle view as well as a lot of old animation layers (visible in a dope sheet) sticking around. Even after I cleared all of those out I still had the phantom geometry however so I'm not sure they are the problem. Even after deleting that the file size is still around 4 mb so there's still something hanging around. Wish I could be more help.
                • #53
                  Everything but SU or Evermotion and still broken.
                  Bobby Parker
                  phone: 2188206812
                  • Ryzen 9 5900x CPU
                  • ​Windows 11 Pro
                  • #54
                    Thanks for looking. I did notice the particle flows and I deleted all the keys, but like you, the problem still exists.
                    Bobby Parker
                    phone: 2188206812
                    • Ryzen 9 5900x CPU
                    • ​Windows 11 Pro
                    • #55
                      How do you delete things in the 'dope sheet'? I was using a script to delete all animation keys, but obviously it's not deleting them all, or something.
                      Bobby Parker
                      phone: 2188206812
                      • Ryzen 9 5900x CPU
                      • ​Windows 11 Pro
                      • #56
                        I used this:
                        Code:
                        macroScript Cleanup category:"3dwannab" buttontext:"Cleanup" tooltip:"Clean Motion Clips + Layer Controls resulting in smaller file sizes"
                        if querybox "Clean Motion Clips + Layer Controls by 3dwannab (◣_◢)\n\nAre you sure ?" title:"Cleanup by 3dwannab (◣_◢)" beep:true
                        	then
                        		t=trackviewnodes
                        		n=t[#Max_MotionClip_Manager]
                        		if n!=undefined then deleteTrackViewController t n.controller
                        		gc()
                        		t=trackviewnodes
                        		n=t[#Anim_Layer_Control_Manager]
                        		gc()
                        		messagebox "Cleanup complete of:\nMax_MotionClip_Manager + Anim_Layer_Control_Manager nodes\n\nGoodbye...(◣_◢)" title:"Cleanup by 3dwannab (◣_◢)"  beep:true
                        	else
                        		-- DO NOTHING
                        • #57
                          I get an error
                          -- Syntax error: at ), expected <factor>
                          -- In line: )
                          Bobby Parker
                          phone: 2188206812
                          • Ryzen 9 5900x CPU
                          • ​Windows 11 Pro
                          • #58
                            Okay, it worked. I initially cut/pasted into the listener. The script worked, but it didn't solve anything.
                            Bobby Parker
                            phone: 2188206812
                            • Ryzen 9 5900x CPU
                            • ​Windows 11 Pro
                            • #59
                              nope, still broken
                              Bobby Parker
                              phone: 2188206812
                              • Ryzen 9 5900x CPU
                              • ​Windows 11 Pro
                              • #60
                                Bobby, I opened the scene you posted, and it works fine for me (Max 2015 SP3, GeForce 780M). I got warnings that I didn't have PSD Manager or the bitmaps, of course. First try setting the Max display to show object colors only, see if that has any effect. If not, maybe you should strip all materials out and see if it's related to that somehow.
                                - Geoff
