Cannot load chaos ventage when using 3dsmax Chinese language
Hello Shusen.ZHAO,
Apologies for this. It appears an issue with the localization on our side.
Could you try copying the necessary files manually? ```
[LIST=1]
[*]Navigate to %Localappdata%\Autodesk\3dsMax\2021 - 64bit\ENU\usermacros
[]Copy the following files[LIST=1]
[*]Chaos_Vantage-UtilityFunctions.ms
[*]Chaos_Vantage-VantageImportChanges.mcr
[*]Chaos_Vantage-VantageLiveLink.mcr
[*]Chaos_Vantage-VantageTransferAnimVrscene.mcr
[*]Chaos_Vantage-VantageTransferStaticVrscene.mcr
[/LIST]
[*]Paste them in %Localappdata%\Autodesk\3dsMax\2021 - 64bit\CHS\usermacros
[*]Similarly from folder %Localappdata%\Autodesk\3dsMax\2021 - 64bit\ENU\usericons
[]Copy the following files:[LIST=1]
[/LIST]
[*]Paste them in %Localappdata%\Autodesk\3dsMax\2021 - 64bit\CNS\usericons
[*]Restart 3ds Max
[/LIST]
You may need to change the 3ds Max version in the paths above.
Let me know if that fixed it for you please.
Simeon
Thank you so much, this solved my problem
