Chaos Vantage v2.5.0 released
Hello everyone,
Chaos Vantage v2.5.0 has been released and here are the highlights.
  • Added initial support for interactive rendering in VR headsets
  • Added support for animated vegetation Cosmos assets
  • Added support for VRayEdgesTex in bump and rounded corners
  • Added support for ACEScg rendering color space
  • Added search filtering and sorting for scene objects, lights, and cameras
  • Added support for animated partial object visibility
  • Added “Flip horizontally” option to the Background image
  • Added tool for quickly saving a previz video with DLSS
  • and more!
​You can find the full change log here:
You can download the update from here:
You can see some of the new features in use here:​​​​
Alexander and the Vantage team​​​
Hello everyone,
Chaos Vantage v2.5.1 has been released and here are the highlights.
  • Cloned animated deforming objects now keep the source mesh animation.
  • Fixed the interactive update of a material on fur objects while dragging and dropping.
  • Fixed Vantage crashes on startup when SteamVR is set as OpenXR runtime.
https://download.chaos.com/?platform=47&product=63​
The Chaos Vantage team​​​​
Hello everyone,
Chaos Vantage v2.5.2 has been released and here are the highlights.
  • Semi-transparent objects after multiple bounces now do not render black.
  • In Color corrections tab Highlight burn option now is available when Filmic tonemap is enabled.
  • Fixed UI input spinboxes are cutoff for sun geolocation and animated geolocation properties.
  • Fixed Wrong skipping of the first camera when importing/merging a .vrscene.​
  • Fixed Motion blur not rendering since 2.5.0.
  • Fixed vertical flip not working in UVW transformation for Opacity map.
  • and more.
The Chaos Vantage team​​​​​
