Enscape for Mac 4.20.0 Released
Dear Forum Community,
We’ve just released our latest version Enscape 4.20.0!
Improvements
  • Composition Gridlines: A grid overlay can now be enabled for the whole viewport instead of only inside the Video Editor, and the option stays reachable while the renderer toolbar is collapsed.
  • Renderer Reset: General Settings now offers a reset of the renderer state, clearing the shader and pipeline caches and the stored configuration, to recover from graphics driver problems without reinstalling.
  • Export File Replacement: When a file of the same name already exists in the destination folder, you can now choose to replace it instead of Enscape adding an index to the file name.
  • Color Management: Rendered images now embed a standard sRGB color profile, so colors stay consistent in post-processing without setting the profile by hand.
  • Light Management: Teleporting to a light in orthographic mode is now a smooth movement instead of an instant snap, matching how it already worked in perspective mode.
  • Archicad: Archicad 29 menus now follow dark mode.
Fixed Bugs
  • SketchUp: Fixed some materials appearing washed out or transparent after updating to Enscape 4.19.
  • Asset Library: Fixed a crash when opening the Asset Library while the Chaos Cosmos service is stopped, so Enscape now explains the problem and picks the service up once it starts.
  • Asset Library: Fixed the Asset Library staying empty on machines where local calls go through a proxy server.
  • Rendering: Fixed rendering a single image ignoring the Synchronize Views setting, so the rendered image no longer differs from the CAD view.
  • BIM Information: Fixed the BIM Information panel staying blank instead of reporting that no BIM information is available.
  • Chaos Assistant: Fixed several unsaved-changes dialogs appearing when dragging assets from the Chaos Assistant.
  • Materials: Fixed Enscape becoming unresponsive after quick successive material changes.
  • Export: Fixed a custom export path being lost after closing the Export window.
  • Artificial Lighting: Fixed stability and correctness issues in artificial lighting.
  • Sky: Fixed sky rendering artifacts appearing when subsampling is active.
  • Stability: Fixed crashes that could happen when an exception handler failed while it was handling an earlier error.
  • Ray Tracing: Fixed shadows not always updating correctly for animated content.
Known Issues
  • Navigation: Movement along the Y axis with the W and S keys is not registered in orthographic view.
  • Performance: Model geometry data can be reallocated repeatedly in some scenes, which can slow down rendering.
  • Chaos Notification Center: Enscape requests system permissions that the Notification Center does not need.
Share your questions or feedback in this thread or by reaching out to support. In case of crashes, freezes or other issues, submit a feedback report with your log files directly.
Happy rendering!
