vray 3.5
  • #91
    Thanks for the suggestion.
    Here are some other problems:
    1. It seems that I can't make region renders while IPR is running UNLESS I start the IPR rendering with a region in the first place. Is this being looked at? Sorry if it was already mentioned.
    2. IPR refreshes when selecting a Color Correction map. This doesn't happen with the Output map. I've not tested all of the maps so you might want to check them and see if others behave the same way. Is it possible to leave it rendering when selecting maps such as Color Correction and refresh only upon change in the map parameters?
    3. The first IPR render that is started is always overexposed. You need to stop the IPR and start it again and then the exposure is correct.
    Originally posted by danio View Post
    Hi Vlado - Thanks for the response. Is this ever going to change? It would be nice to use DR for IPR. It seems like to me (maybe my imagination?) that Activeshade is a lot slower...I suspect I'm missing a level of understanding about the differences between the two.
    Thanks,
    Daniel
    I'm finding that IPR is a lot faster than RT CPU too (tested on an i7 4930k). Maybe about 2 x faster according to my quick tests. So is there a reason to use RT CPU if you use just your local machine? Shame that IPR doesn't support DR... yet.
    PS: I just got my first 3.5 beta crash. I started the IPR and it didn't update the rendering, although my CPU was at working at 100%. I tried hitting the STOP button but it wouldn't work. Then 10-15 sec. later max crashed without a save dialog. The scene was really simple - a very simple room with a wardrobe against the wall, a carpet with Vray Fur and 2 Vray lights. By the way, is this the thread to report any issues with the beta or I should post in the Problems forum?
    Aleksandar Mitov
    www.renarvisuals.com
    office@renarvisuals.com
    AMD Ryzen 9 9950X 16-core
    96GB DDR5
    • #92
      Hello,
      A note about:
      This actually is a bug with the color correction map - when selected it sends change notifications. You get the same behavior with the ART render too
      We reported the issue to Autodesk.
      Yavor
      Yavor Rubenov
      V-Ray for 3ds Max developer
      • #93
        Yes, will fix it.
        See Yavor's comment above. It's a bug in 3ds max.
        Can you get me a scene for this to vlado@chaosgroup.com so that I can fix it?
        Not so much, which is why we are trying to position V-Ray RT more as a GPU renderer.
        Can you send me either the crash dump or the scene to vlado@chaosgroup.com so that I can fix it?
        Anywhere is fine, but we are more likely to see the post if it's in a new thread.
        • #94
          Thanks for the reply, Vlado. Scene sent. This is also the scene where the IPR renders look overexposed through the camera view. I found the real culprit. It wasn't that the first renders come out like that. The problem occurs when the IPR is started through a non-camera view. Then if you move to a camera view the render remains overexposed. To avoid this one should start the IPR through the camera first. This issue however shows another problem with IPR too. Sorry if it was already mentioned. It seems that the IPR respect only the exposure of the first view you started the IPR in. So if you start it in a camera view with certain exposure setting and then while IPR is running you switch to a camera with another exposure settings they do not have effect. Does that make sense? Let me know if I should explain better or make a video.
          Aleksandar Mitov
          96GB DDR5
          • #95
            Thanks for the clarification - yes, I know about this issue, will be fixed.
            • #96
              Just a question - is it possible to make IPR update only when changing parameters of lights that are turned on? I was working with some lights when I found out they aren't on but the IPR refreshed the VFB every time I adjusted their properties.
              Aleksandar Mitov
              96GB DDR5
              • #97
                Yes, will make a note about it.
                • #98
                  Hi Vlado - Any plans to make IPR available for DR? Would it just take a demo install of Max?
                  • #99
                    It is somewhat complicated to keep the scene in sync on all DR servers as the user makes changes to it. We might investigate this in the future.
                    • Originally posted by vlado View Post
                      Ok, thanks for the info Vlado. It sure would be cool to see, most of my horsepower is in my farm.
                      Daniel
                      • Any way to get the denoiser to work when using Render to Texture?
                        Brendan Coyle | www.brendancoyle.com
                        • Originally posted by cheerioboy View Post
                          You can denoise the render to texture output files using the standalone Denoiser tool. There is a thread on the same topic here:
                          http://forums.chaosgroup.com/showthr...render+texture
                          Tashko Zashev | chaos.com
                          • Something interesting from Corona posted a few minutes ago. I don't know what's the purpose when you can do the same with regions but maybe it has its applications:
                            Aleksandar Mitov
                            96GB DDR5
                            • I think it's a comfort thing. It may be good for a low or medium priority implementation in VRay in my opinion.
                              Software:
                              Windows 7 Ultimate x64 SP1
                              3ds Max 2016 SP4
                              V-Ray Adv 3.60.04
                              Hardware:
                              Intel Core i7-4930K @ 3.40 GHz
                              NVIDIA GeForce GTX 780 (4096MB RAM)
                              64GB RAM
                              DxDiag
                              • Yep... a comfort thing. People complained they can not zoom in VFB while IPR. Now they can, and with added benefit of Corona rendering only that zoomed region. I think it will be another one of those "really easy to get used to, really hard to let go of" things
                                But for V-Ray, there are a lot more important things on the table I think.
