Negative horizon offset for VraySky to shift the horizon upwards. Right now the lowest value is 0.
New feature ideas 4
This is a sticky topic.
Cryptomatte improvements:
- Cryptomatte material differentiation between materials with the same name. As reported already, when materials share the same name, whether or not belonging to different multisub materials, Vray considers them the same material for masking, not sure what happens in compositing software. Unfortunately when working with external assets, people tend to name things like trunk or leafs, which, if you have 50 plants and trees from different sources, can be quite a hassle to rename manually. (VrayCryptoMatte, doesn't work with Xref Materials. - Chaos Forums)
- Please fix the bug where some symbols like = or ; in object names or material names makes cryptomatte not work for masks
- Make cryptomatte work with Xref Materials from Xref Objects. Right now they don't work. I've put this on the wishlist although it's considered a bug (VMAX-13406), but for me it's a big wish to have this working.Last edited by Vizioen; 28-05-2024, 02:31 AM.
- Likes 4
Can we get Shutter Efficiency and Bias controls to work with VrayPhysical Cameras (and ideally be set in the camera itself)? Right now to get those effects you have to switch to a Max camera, enable motion blur in the render settings, and you have to setup exposure in the environment panel if you have been using it with the VRayCamera. Would be nice to just have these controls in the camera itself.
Or tell me I am doing it wrong and that there is a way already.
Thanks.
VrayVolumeMTL: Exclusive Tutorial: Create God Rays with Chaos Corona Render (youtube.com) just like corona, to set something similar up in Vray is just cumbersome.
Originally posted by Vizioen View PostVrayVolumeMTL: Exclusive Tutorial: Create God Rays with Chaos Corona Render (youtube.com) just like corona, to set something similar up in Vray is just cumbersome.
Lele
emanuele.lecchi@chaos.com
Disclaimer:
Originally posted by ^Lele^ View PostThe setup is identical in V-Ray, only one has to use the ScatterVolume shader, and the "directionality" parameter is called "Phase" for us.
Thx Lele I was testing this before posting but couldn't get the results I wanted. After some more fiddling I managed to get something more close although I'm not sure what values are 'correct' for the scatter radius, or what the math behind it is as I have to put very large values in here (150000) for my scene to not appear complete black. Is there some sort of rough calculation we can use to estimate which ballpark might be ok depending on size of the volume / scene?
My scene also crashed a couple of times when using IPR and changing some values. Even with just a vraysun + clouds and a vrayplane (grey material), on a resolution of 700 x 1000, without the volumematerial + box (just to test the position of the clouds / sun), IPR updates extremely slow, probably because of the clouds.
Add shadow softness/sharpness controls in V-RayDome (with HDRI).
(Control the size of light-generating pixels within HDRI?)
In other words, if the Dome texture sampling generates internal lights, it would be nice to be able to adjust the size of the lights (soft shadows/sharp shadows).
OakCorp Japan - Yuji Yamauchi
oakcorp.net
v-ray.jp
- Likes 1
A little announcement - we now have a dedicated portal for sharing ideas - http://chaos.com/ideas/vray
The "New feature ideas" threads will remain active as long as we need them. In the meantime you can give a good initial push to the new portal by adding the things from here
Peter Matanov
Chaos
- Likes 3
Originally posted by matanov View PostA little announcement - we now have a dedicated portal for sharing ideas - http://chaos.com/ideas/vray
That's nice, a lot more handy. But in the subcategories, I think you should add a VFB section as well. Too important for the artist.
Originally posted by dimitar_panayotov View Post
Hi, since VFB is a shared component between the integrations, it has its own Space. it's the last option at the bottom. Please use it to share your ideas. Thanks
- Likes 1
So when I'm not logged in on the ideas portal, I can't see the ideas I posted, not sure if that's normal behaviour.
