Archived Old Bugs
This topic is closed.
  • ***PLEASE POST ALL V-Ray for Rhino 1.0 BUGS HERE***
    in the meantime, if you use lightcache, use store glossy. For me it helped rendering SSS without crashing Rhino
    You can contact StudioGijs for 3D visualization and 3D modeling related services and on-site training.
      Thank you Corey and Gijs.
        The simple Rhino materials support the Vray shiny plastic, but if I press the "metallic" button, than I see no effect. I think, if the user press this button, than the fresnel effect could be disabled for a metalic reflection.
        I like to use the simple Rhino material for simple mass materials.
        • COPY/PASTE Between windows not copying materials
          When I copy an object from one window an paste into another instance of Rhino it does not copy the materials into the library. I often have libraries of objects in a file and copy them from one file to the other. Is this not possible with VRay?
            Is a known bug and will be fixed. In a previous version it was working fine.
              Yes Micha is right - sorry for the inconveniance.
              Joe Bacigalupa
              Developer
              Chaos Group
                no worries, just wanted to bring it to your attention. Thanks guys.
                • Weird Buckets (re-post from main bug area)
                  This is a repost since the topic was in the main bug area (wrong place). I am still getting the errors when I have soft shadows on som eproducts. Doesn't matter if it's a direct light with a radius or an area light.
                  ---ORIGINAL MESSAGE ---
                  Hey Everyone. I've been rendering a lot of things on white for work, and I've been getting some weird results. Lately, I have noticed that certain buckets appear to be rendering slightly darker than their neighbors. Here are some examples:
                  The set up for all of these is fairly simple, just one area light and some GI on a white sweep.
                  It looks like the problem comes up when I have texture maps in that particluar bucket. (Notice that the errors are often in buckets containing a MAP). Refer to the first image for a good example. Hmmmm.
                  here's a zip file with the options, the scene, and the light cache and textures ....
                  http://www.orange22.com/tmp/RenderError.zip
                  Any Ideas?
                  Also, it would be neat if there was a button in The VRay options window to export all of the settings to the clipboard as text so it would be easy for us post them for support. Just a thought.
                  Thanks in advance.
                    Try for workaround to use an other GI method. I would test LC-IM (-3/-1 and 64 samples), maybe it help.
                      If I use the sRGB mode and save the image in png format, than it is saved as RGB. The framebuffer support a simple good postwork, so it would be nice, if the user could save what the framebuffer show.
                        Ok - I'll see what I can find out about that
                        Joe Bacigalupa
                        Developer
                        Chaos Group
                        • Re: material mapping of a clone- object
                          Originally posted by mackl
                          hello
                          i`m not sure about this bug(?!), but if i copy an object and change the mapping settings of the original /first object- the changings of mapping applies to the clone, too.
                          thank you
                          mackl
                          I have read at the rhino forum, that this is like the RCM tool works.
                            If I set a spot light to a plane and set hardness 0, than I get a soft edge of the spot, but in sRGB mode, the spot show a hard edge allways.
                              Transparency mapping is not visible in the z-depth pass. So I can not add a post fog effect to an exterior rendering with billboard trees.
                                Ok - I'll see what I can find about those. Thanks
                                [edit]
                                For the transparency mapping - are you saying that none of the layers transparency maps show up in Z-Depth? Does that mean that a straight-up color (no map) will show up Z-Depth?
                                Joe Bacigalupa
                                Developer
                                Chaos Group
